R56 Wheels fitment issue.
Old Mar 13, 2016 | 08:15 AM
Ryan Caballo's Avatar
Ryan Caballo
Hello all,
I recently bought a set of MB weapons from discount tire online. The problem is the OE lug bolts won't go through the holes on the wheels? I called the company and they're sending me tuner lugs, but will that work since the lug bolt itself won't fit through the holes at all?
Old Mar 13, 2016 | 10:18 AM
SpuuDy's Avatar
SpuuDy
Originally Posted by Ryan Caballo
Hello all,
So the oe bolts aren't long enough?
Old Mar 13, 2016 | 11:52 AM
DneprDave's Avatar
DneprDave
Your wheels are probably drilled for 12 mm lug bolts and Series two MINIs have 14 mm lug bolts. It sounds like Discount Tire sent you the wrong wheels, for a series one MINI.
Old Mar 13, 2016 | 01:03 PM
Ryan Caballo
It's not the bolts are long enough, it's the bolts are too thick. I think you may be right about my bolts being 14mm and the drill be for 12mm.
Old Mar 13, 2016 | 01:11 PM
Ryan Caballo
Also what about the conversion kit from a 14mm to 12mm lug stud? For regular daily driving use? Is it really frowned upon?
Old Mar 13, 2016 | 04:14 PM
hsautocrosser's Avatar
hsautocrosser
Do you have hub centering rings?
Old Mar 14, 2016 | 03:54 PM
Ryan Caballo
Yes I do.
Old Mar 15, 2016 | 01:14 PM
hsautocrosser
In that case I would expect the smaller lug conversion to be ok in normal driving. Way Motor Works, a respected MINI specialist, sells the kits for the purpose you are considering:
http://waymotorworks.com/m14-to-m12-...rsion-kit.html
Old Mar 16, 2016 | 04:57 AM
gjxj's Avatar
gjxj
you should not need to do a stud conversion for new wheels that were specd to fit. They should replace the wheels with ones with correct holes. Do you have a local tire discouters shop? Have them look at it.
Jas0n
Aug 21, 2017 06:58 PM
penguinhomey
Mar 18, 2016 08:32 AM
XsV
Tires, Wheels, & Brakes
Mar 14, 2016 12:15 PM
yukinoinu
Mar 9, 2016 08:01 AM
MiniKar
Mar 8, 2016 07:59 AM
