R50/53 Need a little advice...
Old Mar 12, 2016 | 08:11 PM
mdaz75's Avatar
mdaz75
From researching the forum I know that first gen minis have significant reliability problems when it comes to the automatic transmission. Was this problem straightened out in the 2005/2006? My wife has her eye on an '06 automatic and I'm wondering if I should steer clear.
Old Mar 12, 2016 | 09:57 PM
Kahnfucious's Avatar
Kahnfucious
This doesn't apply to the S model. Different transmission altogether. Is it an S (supercharged) or just regular - non S.
If the non S - no they didn't sort out the issue.
Old Mar 13, 2016 | 05:15 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Main issue for this transmission was the lack of (scheduled ) maintenance. Transmissions for any car should be flushed at 30K. If the one she is looking at has low mileage ( say under 50K ) have the dealer perform a flush and re-adaptions/program. Seen a few on original fluid still running AOK with 100K on the meter, but IMO unless an S as Kahn states, steer clear.
Old Mar 13, 2016 | 05:43 AM
mdaz75's Avatar
mdaz75
It's a non-s with 81,000. It looks like I'm going to be letting that one go. Thanks for the info, it's greatly appreciated!
Old Mar 13, 2016 | 06:57 AM
Mini3333's Avatar
Mini3333
A
Old Mar 13, 2016 | 09:05 AM
mdaz75's Avatar
mdaz75
Originally Posted by mini_wisconsin
The CVT was in the 2002 - 2006 non S models. It was also used in the convertible from 2005 - 2008.
Ok, so, just to be clear, the automatic in all first gen S's are fine? Another question, how about second gen S's, anything to avoid? I've read that 2007-2010 have their problems, but are they that significant?
Old Mar 13, 2016 | 10:20 AM
Mini3333's Avatar
Mini3333
Yes the 1st gen S models are fine...no CVT
The other MINIs to avoid because of the N14 engine are:
2007 - 2010 MINI S
2008 - 2010 MINI Clubman S
2009 - 2010 MINI S Convertible
and the factory JCW through 2012
The N14 engine has carbon build-up issues, excessive oil consumption and timing chain problems.
These cars are a lot of fun to drive. Good luck.
Also, there is a free BMW VIN decoder online which will allow you to check the engine and transmission type.
Old Mar 13, 2016 | 11:38 AM
ZippyNH's Avatar
ZippyNH
The auto tranny in the S did not appear till 2005.....the same basic tranny was used on VW and Toyota cars...so it is not a unique unit, unlike the unit on the non-s, which was a CVT..... some did have valve body issues....hung shifts or delayed shifts...you can test drive it ti find out...VW/audi actually did a recall on some units...NOT MINI...
Many folk NEVER changed their fluids.....AND IN A HARD DRIVEN car, it is important...heat and old fluid are the enemy...
Know that a 10+ year old tranny on a 10= year old car is a risk...especially when driven hard....ask for records...do your due diligence...but most any car in this age range will be a risk.....lets face it...if driven hard, and the fluid is not changed, ANY 10 year + tranny is on borrowed time. Just telling you how it is.
Old Mar 13, 2016 | 11:40 AM
ZippyNH's Avatar
ZippyNH
Hey good too see you back!!
+1 on the advise too!!
Thanks, good to see you stuck around Tim !!
Old Mar 13, 2016 | 11:46 AM
DneprDave's Avatar
DneprDave
I have a 2010 MINI Clubman S with the N 14 engine and automatic transmission. I purchased it new, it burns no oil and has been trouble free.
Old Mar 16, 2016 | 08:08 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
+1 to keeping up on the services. http://www.pelicanparts.com/catalog/..._pg1.htm#item3
Same with keeping up on the cooling system and frequent oil changes. Just be sure to maintain it well.
888.280.7799 | 6am - 5pm PST
TREX
Mar 5, 2020 08:17 AM
Un0RiGiNaL
Dec 30, 2016 10:36 AM
Germain Jean Pierre
21
Jun 29, 2016 01:01 PM
vegasMCS
16
May 3, 2013 09:30 PM
cWade
Dec 9, 2011 12:19 AM
