R50/53 Antifreeze leak/overflow help
What causes the radiator fluid/antifreeze to overflow out of the reservoir after running the car? Engine was not overheating - OEM temp gauge shows just slightly below halfway mark. Supplemental cooling fan did kick on and was running when I got out and I noticed fluid leaking steadily. Fluid was that spendy Pentosin stuff. Was steaming/flowing out from the cap on the new aluminum coolant reservoir tank. About to be done with this car. Love it and am now hating it. Suggestions?
Did you put a new cap on when you got the tank or reuse the old one? I'd check the cap and make sure it's not in poor condition.
888.280.7799 | 6am - 5pm PST
Reused it. Because I'm either cheap or broke after all the $$ i've spent on the Tardis in the last six months.
Check and make sure the seal on the cap isn't bad. It's also good, as mentioned above, to make sure there isn't too much coolant in the system.
https://www.northamericanmotoring.co...erflowing.html
https://www.northamericanmotoring.co...-overflaw.html
Have patience. On the aluminum recovery tanks, (Forge, Canton, etc.) you want coolant only about 1 inch above the bottom when cold. Use a piece of wooden dowel to check. Then go buy yourself a higher rated pressure cap...22-24 Pounds.
When that was happening to me it was a bad thermostat. Temperature was normal both on the gauge and via obd, but it was still bubbling over. I have the Forge tank too.
thebombardier
Tires, Wheels, & Brakes
14
Mar 10, 2016 02:57 PM
Gizmotech
Mar 5, 2016 07:00 AM
PelicanParts.com
Mar 4, 2016 03:39 PM
