R56 lower control arm bushing replacement info?
Old Feb 8, 2016 | 06:14 PM
photoputz83's Avatar
photoputz83
so i noticed that my steering has been less responsive, as well as more lateral motion in the front suspension while applying force to the wheels. i inspected the bushings and fount that they were torn. its time to replace them, so i picked up a set of assemblies, and had urethane bushings pressed in. i was wondering if there are any good resources online that show the process of dropping the subframe, as well as the installation process. i was looking at installing urethane sway bar bushings and strut mounts as well. im mostly looking for the subframe bit. any help would be great.
Old Feb 8, 2016 | 07:50 PM
grussell's Avatar
grussell
Here are 2 videos on how to replace the bushings without dropping the subframe. I used this method when I changed them on our first gen MINI.
Old Feb 8, 2016 | 07:59 PM
grussell's Avatar
grussell
And another
Old Feb 8, 2016 | 09:02 PM
photoputz83
it seems like a horrible idea to torch on any suspension component. and the last video is of an r53 using a saw lol. i found a step by step on how to lower the subframe. just took a bit more digging than i expected
Old Feb 9, 2016 | 05:08 AM
GAT's Avatar
GAT
Can you please share your findings? I'm interested in this as well. Thanks.
Old Feb 9, 2016 | 08:30 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
We have a front control arm replacement DIY that might be helpful HERE under tech info (tab at top) > R56 articles > Suspension > Front Control Arm Replacing.
888.280.7799 | 6am - 5pm PST
Old Feb 9, 2016 | 10:16 PM
photoputz83
here is a link to removing the lower control arm bushings without removing the subframe completely. you still need to lower it but it saves time and allows for removal of less parts throughout the process. i estimate the total time involved to be 3ish hours. obviously will be easier if you have access to a lift, but as shown is possible on jack stands.
http://www.*********************/lib...g-subframe-62/
photoputz83
Old Feb 9, 2016 | 10:17 PM
photoputz83
actually it wont let me post the link thats crazy
Old Feb 10, 2016 | 07:52 AM
PelicanParts.com
Vendor
That forum is banned from being posted on here. They have to type in the forum name in place of the *'s.
Old Feb 10, 2016 | 07:57 AM
+1 on doing the powerlfex or superpro LCAB : https://www.ecstuning.com/Mini-2007-Cooper-R56-S-Coupe-L4_1.6L_N14B16A/Suspension/Control_Arm/
While you are there I would make sure the inner and outer ball joints are good.
https://www.northamericanmotoring.co...placement.html
If you have a lift and support the back of the subframe on a Transmission jack , its easier to loosen and lower and watch your head , its easy to bang it on the it of the sub frame mount. Ouch.
kazyn
Apr 7, 2016 03:35 PM
cjny
Jan 21, 2016 01:30 PM
Sprout06
Jan 18, 2016 10:12 AM
vulkandino
Jan 16, 2016 10:59 PM
Suspension Products
Jan 13, 2016 12:31 PM
