F55/F56 How long before battery change in Key Fob ?
Old Jan 27, 2016 | 03:26 PM
Pedro99's Avatar
Pedro99
Anyone have to change the battery in their Key Fob ?
If so how long did the original battery last ?
What type battery is needed ?
Old Jan 27, 2016 | 03:36 PM
whaap's Avatar
whaap
In my '13 the battery is rechargeable when inserted in the car. However, when not used for a long time it can go flat. I change back and forth between my two fobs every oil change.
Old Jan 27, 2016 | 04:07 PM
anotherminiinthegarage's Avatar
With the F56 the battery is not rechargeable.
Old Jan 28, 2016 | 11:39 AM
siriuszero's Avatar
siriuszero
I had comfort access on my Countryman so it used a replaceable battery, similar to the 3rd gen MINIs. It lasted about 1.5-2 years before I replaced it.
The new fobs are the same - you'll probably get a couple years out of them. The car will let you know when it detects the battery getting low and they are easy to replace. The cover on the back pops off and you replace it with a standard button cell battery (a CR2030 or something)
Old Jan 28, 2016 | 02:16 PM
Pedro99's Avatar
Pedro99
Good to know.
Old Jan 28, 2016 | 02:33 PM
Yea, they should last a while my r56 one lasted a long time the CA ( comfort access ) battery did need changed once. Just switch the keys every so often.
Its a CR2032 battery
https://www.ecstuning.com/Search/SiteSearch/ES2682246/
Old Feb 14, 2016 | 06:41 PM
Miata13's Avatar
Miata13
??? Photo shows a CR2025 battery...narrative states a CR2032. Is there a difference between the two?
Old Feb 14, 2016 | 07:40 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Amperage difference and thickness. In some applications you can use either, not sure about your key fob however.
Old Feb 15, 2016 | 10:45 AM
Thats battery in my R56 and R58, Show for the F56 / F55 also: 66126912985 3,2 V - CR2032
http://www.realoem.com/bmw/enUS/show...26#66126912985
marshallpre1
Nov 6, 2023 05:33 PM
andersonspedini
Nov 6, 2018 12:39 PM
Toolz
Aug 31, 2016 12:25 PM
mni928
Mar 1, 2016 06:00 PM
1drummer
Jan 22, 2016 10:59 PM
