R56 Clutch/flywheel difference
Old Jan 24, 2016 | 07:46 AM
Ryan Chamberlain's Avatar
Ryan Chamberlain
I'm in need of a new clucth. Is there really a difference between the turbo clucth/flywheel and supercharged version?
Old Jan 24, 2016 | 07:29 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes they are two completely different clutch and flywheels. You can't interchange any of the parts.
Old Jan 25, 2016 | 01:24 AM
Ryan Chamberlain
So if the compatible models are simply 's' models it probably won't work? I'm looking a a valeo flywheel conversion kit. Just says s model 07 no turbo or supercharged.
Old Jan 25, 2016 | 12:03 PM
nkfry's Avatar
nkfry
You'll need to confirm with the vendor selling the product. As Way said, the -G1 and G2 clutch/flywheels are two totally different part conglomerations.
The first gen cabrio's went into 2008, and second gen production started in 2007, so you need to verify if it is for the first generation or second generation.
Valeo does sell a clutch kit, which is just the pressure plate, throw out bearing, and friction disc, but you still need to buy a flywheel.
If you have any questions or wanted to get the kit ordered we can help you out, and assure that you are getting the proper parts for your job.
Nick
586-792-6464
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jan 25, 2016 | 12:50 PM
No DM to SM conversion from Valeo, that's first gen, and like everyone says " two diffrent set up , not the same. "
If you want a Dual mass to single mass conversion look at the clutch master in the steel flywheel kit. FX100
https://www.ecstuning.com/Mini-2008-Cooper-R56-S-Coupe-L4_1.6L_N14B16A/Drivetrain/Clutch/
Old Jan 25, 2016 | 03:10 PM
Ryan Chamberlain
What about the south bend? I'm poor and I'm slipping in second gear. Was only 6th this morning.
Old Jan 26, 2016 | 05:13 AM
South bend only makes the clutches for the Gen 1 MINI, which we carry . Not gen 2. For Gen 2 we have the clutch master version.
Old Jan 26, 2016 | 06:51 AM
nkfry's Avatar
nkfry
Unfortunately you're stuck with 3 options:
Stock
Clutchmasters (Which we've had multiple failures on the G1 cars and stopped pushing)
OS Giken
The stock clutch will get you the same life, same feel, and same failure. But it is very easy to drive in traffic. The Giken is going to be a bit more of a pain in traffic and hill starts, but is a GREAT feeling clutch. It also comes with a full steel throw out bearing, made in house at OS Giken soley for use in their clutch kits.
If you're looking to save money then stock is going to be the recommendation I give you, Clutchmasters has left a sour taste with us after multiple failures.
Phone:586-792-6464
Old Jan 26, 2016 | 08:40 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
It's also a good idea to replace a few other things while you're in there doing the job, but otherwise we have the Genuine clutch kits HERE as well. You'll need to check the condition of your flywheel to see if you can resurface it, otherwise you'll need a new one.
888.280.7799 | 6am - 5pm PST
Old Jan 26, 2016 | 12:45 PM
Aelwulf's Avatar
Aelwulf
Stock
OS Giken
Also has JMTC as an option (various prices but most under OS Giken - linked their R56 clutch kit page), and I believe SPEC (although they seem to be getting a similar rep as ClutchMasters).
I'd say Valeo/stock if not planning much by way of upgrades (possibly with a single flywheel such as the JMTC conversion). Otherwise JMTC or OS Giken personally.
Old Jan 26, 2016 | 05:36 PM
enoe01's Avatar
enoe01
If you want to save some cash, check out Auto Parts Warehouse and Auto Parts Way, I saved some cash by purchasing my clutch kit and dual mass from them for my 2007 MCS. I am replacing the clutch this week I hope. Below are part numbers that you should check out. I ordered the bolts, rear main seal, MTL Redline and few other parts u should replace from pelican parts. If you are interested in getting all the info PM me.
Autopartswarehouse http://www.autopartswarehouse.com/
Clutch Kit Part #: W0133-1975444
Valeo Clutch Kit Clutch Kit
Valeo
Qty: 1.00
Price: $ 221.95
Auto Parts Way http://www.autopartsway.com
Dual Mass Flywheel
Part Number: SACW0133-1829787
Part Name: Clutch Flywheel
QTY Ordered: 1
Item Price: $477.40
Item Total: $477.40
Tweedbean
Sep 20, 2018 06:41 AM
GP1735
Mar 10, 2016 01:27 PM
bcriverjunky
Feb 25, 2016 03:21 PM
dez
Feb 24, 2016 09:05 AM
Jan 18, 2016 04:09 PM
