R56 Brake upgrade
Old Jan 13, 2016 | 12:09 PM
R56CPRS's Avatar
R56CPRS
Brake upgrade
Thinking of upgrading my brakes for my 2013 R56S. Running 18" wheels so want to fill them up and get some more braking power for my upcoming tune.
Anyone any experience with these guys: http://ceikaperformance.com/Custom-B...Kit-p1884.html
Thanks!
Old Jan 14, 2016 | 08:06 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Those kits are really expensive, check out the Wilwoods they work great and more cost effective.
http://www.waymotorworks.com/07-coop...es/brake-kits/
Old Jan 15, 2016 | 07:19 AM
R56in's Avatar
R56in
+1
I can also recommend the Wilwood brake kits. They are top quality and at a reasonable price.
Old Jan 15, 2016 | 08:24 AM
toddtce's Avatar
toddtce
Thanks!
I can offer you an opportunity to fill them up with kits as large as 14" up front and 11.75 rears.
TCE has even done a couple of 13" rear kits over the years but beware; those do require some futzing to make it all work.
The larger 14" kit are more costly than the box 13" front kits. Like any purchase, to some degree much of your choice will include a review of costs.
The more 'value packed' kits would be a four wheel 13/11.75 set up. All in what you want, what you expect from it, and what you're budget is.
Old Jan 15, 2016 | 09:09 AM
R56CPRS's Avatar
R56CPRS
Thanks - someone mentioned that the Wilwood rear brakes are very difficult to install. I found a new OEM JCW big brake set for 1750 (from mini dealer) so thinking to go for that.
Old Jan 15, 2016 | 09:50 AM
toddtce's Avatar
toddtce
To clarify; the rear kits are quite easy to install. The PITA portion is not the brake kit but the replacement cable kit necessary on the R56 and all aluminum trailing arm cars. (the stamped steel ones R53 can use the current parts without a lot of work) The replacement cables require some extensive effort to replace them in the cars 'tunnel' which can be a bit of a challenge and time consuming.
DETAILS
Old Jan 15, 2016 | 11:15 AM
squawSkiBum's Avatar
squawSkiBum
Moderator
That's a REALLY good price for the JCW kit (assuming it includes front and rear calipers and rotors.)
Old Jan 15, 2016 | 11:19 AM
R56CPRS's Avatar
R56CPRS
Yeah, that's what i thought too. The SKU is 34110432802 - 99.99% sure that's the complete set.
It's sold by an official mini dealer so also sure it's legit...
Old Jan 16, 2016 | 05:29 PM
sgscomps's Avatar
sgscomps
The OEM MINI kit listed above requires specific wheels http://www.outmotoring.com/mini-coop...brake_kit.html
Old Jan 17, 2016 | 06:16 AM
ridinDirty's Avatar
ridinDirty
I got the kit from TCE , nice you can pick the color you want the calipers to be plus the color of the Wilwood name on them.
I went silver with red writing!!
Old Jan 18, 2016 | 10:01 AM
R56CPRS's Avatar
R56CPRS
Thanks - I have the 18" NM Rse12 so kit should fit no problem
R56CPRS's Avatar
R56CPRS
Ordered the JCW kit. Thinking about powder coating the calipers in yellow though. Does anyone have any recommendations on where to get that done?
Thanks!!!
Bosgarage57
Tires, Wheels, & Brakes
Dec 28, 2015 10:52 AM
Gear Junky
Dec 26, 2015 11:16 AM
Bosgarage57
Dec 22, 2015 07:23 PM
tylewis
Dec 21, 2015 11:55 AM
TREX
R58 :: Coupé Talk (2012+)
Dec 21, 2015 11:54 AM
