R50/53 Possible to retrofit euro headlight level to US-spec R53
Old Jan 7, 2016 | 04:39 AM
ApexinM3's Avatar
ApexinM3
Good morning, y'all! Question for the more tech savvy folks on here: my OCD is gnawing at me with the switch blank in my euro parcel shelf. On the euro-spec cars there is a headlight level switch in that blanks place. Is it possible to install and wire in the manual headlight level switch and have it functional or am I just going to have to chill on my OCD? I understand doing so would bypass the US-spec auto level switches on the suspension.
Thanks in advance for the input!
Old Jan 7, 2016 | 11:08 AM
Yea, its a factory part in certain counties that require the manual adjustment.
https://www.ecstuning.com/Search/Sit...460/ES2674998/
Pics here:
You would have to wire it to the motor of the headlight to it to adjust. Most people run the blank below or use it for an aftermarket switch.
https://www.northamericanmotoring.co...f-photo-2.html
More info:
You dont have the wires, so you would have to make something custom.
https://www.northamericanmotoring.co...3-w-xenon.html
Old Jan 7, 2016 | 11:27 AM
ApexinM3's Avatar
ApexinM3
Thanks for the input, ECS, you are correct with what I am trying to do. I abhor aftermarket switches as they always look out of place (in my opinion). My OCD is a bit extreme: I went so far as to obtain switches and pigtail harnesses for my '02 4Runner to disable the daytime running lights, power antenna, and VSC/Trac system!
As for my MCS, the wires won't be too much of an issue as I was able to obtain a euro switch with pigtail harness. I'd planned on running them when I install my driving light set but I will have to search for the wiring diagram to perform the conversion. I was hoping someone else had done this before and could get some guidance from them but alas my search of NAM turned up nothing.
Old Jan 7, 2016 | 11:51 AM
Welcome.
Yea, not too much about these rare older euro parts. Most people I have seen put the rally light factory switch , or a rocker switch. Only seen it in euro cars but that was factory.
If i find anything i will post up.
rk15000
May 5, 2017 02:44 PM
wrnchhd
Feb 8, 2017 04:51 PM
wrnchhd
May 1, 2016 08:32 PM
dube53
Jan 4, 2016 12:22 PM
Red Raven
Jan 4, 2016 07:16 AM
