R50/53 Any advice for replacing Struts & Shocks ?
Old Dec 28, 2015 | 12:32 PM
Morganinaboat's Avatar
Morganinaboat
I'm planning to DIY replace the front struts and strut mounts, repair mushrooming towers, install Craven speed UTIs, and replace rear shocks. Not looking to lower or anything fancy. Then I'll take the Tardis to have a professional alignment.
Got Bilsteins from the guys at Pelican Parts and am just curious if my R53 brethren or sisteren have any advice. Thanks! and Happy New Year!
Old Dec 28, 2015 | 01:34 PM
nkfry's Avatar
nkfry
I'm more a fan of the Craven strut tower defenders as they are more robust, easier to install, and don't raise the front of the car.
As for tips, even though you're in GA I would recommend a penetrating oil on the front shock pinch bolts as well as having at least a MAP gas torch (oxy/acetylene preferably) to keep from breaking the bolts off in the steering knuckles. (Not a fun job at that point)
Aside from that, make sure the springs are clocked properly in the front, everything that comes off needs to go back on, torque to spec, and enjoy.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 28, 2015 | 01:38 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Thanks for your order. Glad we can help you and Tardis. We also have a great Front Shock and Spring Replacement and Rear Shock and Spring Replacement DIY tech article on our site that can help you with the replacements. Each article gives you a great step by step process with tips and tricks like this below:
One thing I discovered while assembling the new strut assembly is that the coil spring has a tendency to rotate independently of the strut when you use an impact wrench to tighten the top nut. This results in the spring unseating itself from the rubber pads on each end. What I ended up doing was making sure that the strut rod had enough threads penetrating into the nut at the top, then lightly backed off the spring compressors. This secured the spring in place against the rubber pads enough to hold it in place while I used the impact wrench to fully tighten the nut on top.
Let me know if you have any questions or need any help during your project.
888.280.7799 | 6am - 5pm PST
Old Dec 28, 2015 | 08:49 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Be aware when you install the under tower plates you will raise the car slightly and reduce the neg camber in the front which you want more of. We just use the top plates with new strut mounts.
When you get ready for your alignment take it to Gran Turismo East they do the best alignments in town.
Old Dec 29, 2015 | 03:28 AM
Morganinaboat
Should I swap the under plates for the top plates? Is that enough of a fix for the mushroomed towers after a sufficient reshaping with the typical 2x4 & hammer method?
Old Dec 29, 2015 | 06:36 AM
nkfry's Avatar
nkfry
The top plates are a great design that doesn't change the ride height, easy to install, and look appealing.
They are what we install on all of our customer cars, we don't stock the under tower systems as they are a more involved install, as well as the previously noted other tag alongs.
Phone:586-792-6464
Old Dec 29, 2015 | 08:37 AM
PelicanParts.com
Vendor
Some advice from our Strut Tower Reinforcement Plate Install DIY. Our R53 runs the Madness plates that go under the strut towers. Madness has some good information as well here. From our DIY:
The solution is to reinforce the area around the strut tower to better distribute the loads placed upon the sheet metal. Various companies offer solutions to this problem by offering reinforcement plates mounted on the top of the strut mount. The problem with this approach is that in order to fit across the top of the mount, a notch must be either cut or formed into the plate to clear the stiffening rib formed into the top of the strut tower. To do this reduces the effectiveness of the plate.
Mini Madness has come up with a different approach to this problem by mounting the reinforcement plate UNDER the strut tower, on top of the strut mount. The benefits of this approach include having a flat surface to transfer the compression load to. Also, the reinforcement plates are made out of thicker gauge steel than the strut tower sheet metal. This means that if your strut towers are already deformed, installation of the plate will pull the towers back into alignment when the mounting nuts are tightened.
Old Dec 29, 2015 | 02:30 PM
Like the top plates and easy to install. Been running mine for some time, no strut mushrooming. Currently on Holiday sale.
https://www.northamericanmotoring.co...ht-mods-3.html
Old Dec 29, 2015 | 07:56 PM
Stripeknight's Avatar
Stripeknight
ECS Tunning, Pelican Parts and Way Motor works all in the same thread soliciting their products. Can we get a few more vultures in here! ;p
Old Dec 29, 2015 | 08:16 PM
WayMotorWorks
Vendor
I would as you don't need to beat the towers much as you can use the plates to pull it back in place. We keep the top plates in stock
http://www.waymotorworks.com/wmw-str...0-r52-r53.html
Old Dec 29, 2015 | 10:58 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
if they all went away you wouldn't have a forum as they pay to play, get over it.
Old Dec 31, 2015 | 09:09 PM
David.R53's Avatar
David.R53
"to keep from breaking the bolts off in the steering knuckles. (Not a fun job at that point)"
This!! And when you do, you can buy decent used knuckles on eBay.
trinigladiator
Feb 22, 2016 07:27 AM
PelicanParts.com
Suspension Products
Dec 30, 2015 01:58 PM
schr5530
24
Dec 9, 2015 08:37 AM
polepino
Dec 4, 2015 09:30 AM
PelicanParts.com
Nov 30, 2015 12:20 PM
