R50/53 Front marker light replacement?
Old Dec 24, 2015 | 07:18 PM
sevin's Avatar
sevin
I have an 08/2003 R53 and I now have a set of Ziza LED front marker bulbs. I'm looking to replace the standard yellow bulbs with these but I can't quite figure out how to remove the old ones. I figure they're #5 in this diagram...
... but I can't figure out how to remove the socket. My Bentley manual does not seem to include the marker bulbs, only the turn signal bulbs, and those instructions are not very clear.
Old Dec 28, 2015 | 08:55 AM
Some help here:
https://www.northamericanmotoring.co...leds-sale.html
Twist the base unit out ( Black base ) quarter turn #3 , Then take the stock wedge bulb out #5 . Then replace with the Ziza bulb. If they dont light up at first test, pull out and swap 180 degrees as they are polarity sensitive.
Old Dec 28, 2015 | 09:23 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
We go over the replacement of the side marker bulb, side turn indicators, etc in our Replacing Lenses and Bulbs DIY.
888.280.7799 | 6am - 5pm PST
Old Dec 29, 2015 | 04:31 PM
sevin's Avatar
sevin
Pelican, I'm talking about the front market bulbs, the DRLs.
ECS, that's what I've been trying to do, it just seems like the black base won't twist out. I have removed the wiring harness, but the #3 black base refuses to turn.
Old Dec 30, 2015 | 06:10 AM
Been there , done that.
Its stuck a little , they can get dirt on that and be pretty tight to get out. Turn to the left , first grab it with your thumb and index finger. Some silicone spray between the socket and the light fixture gap will help. Then twist out which pushing in a hair.
Old Dec 30, 2015 | 11:59 AM
sevin's Avatar
sevin
Okay, finally got the thing unfastened and replaced. Thanks for the help! Comparison pics tomorrow in my build thread.
Old Dec 30, 2015 | 12:08 PM
Great, yea, it takes a bit of force on any of those plug types if they have never been turned.
Old Jan 2, 2016 | 09:06 PM
Andrew Riley's Avatar
Andrew Riley
WD-40 works wonders... Especially on that "years old" brittle plastic.
Old Jan 4, 2016 | 08:59 AM
+1 that also will work, good point, just make sure not to get it on the bulbs itself.
CountryS
Nov 20, 2015 02:59 PM
Rennfahrer555
Nov 18, 2015 03:31 PM
flredmini
Nov 17, 2015 04:08 PM
WhinyR53
Nov 9, 2015 09:13 AM
AvianMan
Nov 3, 2015 11:00 AM
