R56 Cranks but doesn't start.
Old Nov 25, 2015 | 04:32 AM
z3ds's Avatar
z3ds
Hi, how can I check for spark and/or fuel? The engine cranks perfectly but doesnt start. Compression is good on all cylinder.
Old Nov 25, 2015 | 08:50 AM
nkfry's Avatar
nkfry
What year car is this? Is it an S or Cooper? Miles?
HPFP been replaced yet?
The ignition system is rather simple I wouldn't suspect it's an issue, unless you've broken or removed a ground strap.
What are your compression numbers?
Has any work been done recently to cause the situation?
What if any stored codes are present?
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Nov 30, 2015 | 06:42 AM
z3ds's Avatar
z3ds
Hi its a 2008 mini s. With 100kmiles. Original hpfp.
Things I did to trouble shoot:
Checked for spark and fuel. Both are absent.
Obd2 reader wont link.
Jumped with another car.
Checked all fuse and swapped relays around.
Compression on all cylinder is good.
I replaced a piston and placed everything back. The car started and ran rough. Then I noticed that the ground strap on the ignition coil harness was placed incorrectly. And the lower intercooler hose clamp was loose.So I turned the engine off and fixed the problem. I tried to start the car again but to no avail. It just cranks.
Im going to try anew battery and check more on connections that might have gotten loose..
Old Dec 3, 2015 | 12:22 PM
imncrxtc's Avatar
imncrxtc
Im having issues with my 2007 S, 230k.....how did you check for spark and fuel? Mine turns over but wont start. Would a bad fuel pump cause these cars not to start?
Old Dec 3, 2015 | 03:10 PM
z3ds's Avatar
z3ds
Hi I checked the spark by following this:
To check for fuel I loosened the nut slightly on the tube coming out of the hpfp to the injectors. Fuel should spray a little when you crank the engine. You should hear the fuel pump on the rear seat prime when you turn the ignition on.
Is you compression good?
Old Dec 3, 2015 | 06:04 PM
imncrxtc's Avatar
imncrxtc
I was told the compression is good.....how can I check?
Old Dec 3, 2015 | 06:21 PM
z3ds's Avatar
z3ds
Use one of these: http://m.harborfreight.com/compressi...-pc-69885.html or check autozone or advance auto if they rent this out.
The guy in the youtube I sent you also has a tutorial on testing the compression on his channel.
Old Dec 4, 2015 | 05:03 AM
imncrxtc's Avatar
imncrxtc
Was the hpfp recalled by mini on these r56's?
Old Dec 4, 2015 | 10:20 AM
No recall, some people getting them replaced in Cali under emissions :
https://www.northamericanmotoring.co...r-r56-jcw.html
Old Jan 7, 2016 | 08:58 AM
z3ds's Avatar
z3ds
Fixed the problem with a new dme. If any body needs to clone their broken dme to a used one the guys at precision auto did it for only $245. You can supply your own used dme or get it from them.
Precision Auto
3034 N Central Ave
Chicago, IL 60634
Old Jan 7, 2016 | 09:06 AM
nkfry's Avatar
nkfry
Not recalled but had an extended warranty placed on the 07-09 S models, 10 year/ 120k miles.
As for the DME needing replaced, I've only ever seen that happening once and that was because another shop did a compression test with the coils still plugged in and the ground strap removed from the valve cover bolt causing some sort of voltage backfeeding to the DME.
Phone:586-792-6464
Turtletears
Oct 27, 2019 08:46 PM
nickbmw
Jan 4, 2016 04:51 AM
Snakeeyeidk
Nov 30, 2015 08:48 PM
schr5530
Nov 25, 2015 12:30 AM
caseyjay
Electrical
Nov 24, 2015 07:27 PM
