R56 adjustable control arms
Old Nov 21, 2015 | 04:29 AM
genik's Avatar
genik
I want to lower my R56S, so i suppose im gonna need rear adjustable control arms right? If so, what are my options in available brands and how should i make my choice? How will i get something good and reliable, what shall i be looking for?
Old Nov 21, 2015 | 06:10 AM
BossyR56's Avatar
BossyR56
Get Hotchkis adjustable control arms.
Old Nov 21, 2015 | 06:27 AM
cristo's Avatar
cristo
Alliance Member
Hotchkis (H-Sport) has poly bushings with zerk fittings, so they can be greased
if necessary and will be effective and durable.
TSW has hard rubber bushings and would be another great choice, but not sure
if they're available right now.
A spherical or heim joint arm has even less flexthan the two above, but would
avoid an open designon a street car, especially if you have winter where you live.
The current Helix arms have a rubber boot over the joints if you want to go this route.
Old Nov 21, 2015 | 10:10 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
I installed the Helix rear control arms over a year ago, not a single rattle or squeak. Very nicely made and I like that the threaded adjustment part is at the ends rather than in the middle.
Old Nov 22, 2015 | 12:26 AM
genik's Avatar
genik
Thanx guys for the info, on the other hand, do i really need RCA if i lower the car or might the stockRCA work?
Old Nov 22, 2015 | 05:27 AM
cristo's Avatar
cristo
Alliance Member
The stock will work, but you will have more negative camber in the back than ideal.
This will result in more wear on the inside tread in the back, and a little more understeer.
With adjustable RCAs, you can optimize things better.
BTW, I'm not a big fan of lowering as the suspension travel is already limited in the MINI.
Most people do it for looks rather than performance.
Old Nov 23, 2015 | 08:22 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yeah we've used all the brands and found the Hsport rear camber links to be by far the best as they are the most reliable and quiet.
http://www.waymotorworks.com/h-sport...ber-links.html
Old Nov 24, 2015 | 10:03 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Any type of lowering you do on your MINI will require adjustable control arms. As everyone has stated, the Hotchkis Adjustable Control Arms are a very quality control arm to go with. They give you camber adjustable from 0 to -4 degrees. You can also get the set of two or the set of four. The lower arms will give you a certain amount of camber adjustability (set of two). All 4 arms will give you a greater range of camber adjustable compared to just the two lowers. Also, with all 4, you can play with the toe adjustment as well. Another little advantage is with all 4 you can kind of play with the rear track width, so you can actually adjust the width of the rear car slightly. Here is the set of 2 installed on our R53. Let me know if you have any questions.
888.280.7799 | 6am - 5pm PST
IQRaceworks
Nov 6, 2015 03:38 PM
agkyle
Oct 26, 2015 10:54 AM
minisenpai
Oct 20, 2015 04:11 PM
Qik420
Oct 6, 2015 12:26 PM
eddyjoe
Oct 1, 2015 05:09 PM
