Mini Cooper S tire fitment 16x8
Old Nov 8, 2015 | 10:18 AM
Mega Babies's Avatar
Mega Babies
Hello all. I need help. I plan on getting Avid.1 AV19 wheels on my R56s that are 16x8 et15. I don't know what tires i need to get that will give it an aggressive look. I have BC racing coilovers and plan on closing the wheel gap. I was looking at 205/45/16. I don't want that tall of a wheel wall. does that make sense? Like i dont want a big tire but i dont want it too thin either.
I am okay with very slight stretching but would recommend none. i don't want too much camber, -2 will probably be the most i'd go. Also its a daily driver, I don't track, yet, and i'm not THAT aggressive, but sometimes like to drive a little hard (who doesn't in a MINI?)
Please Help! i'm new to fitment and could use some help soon!
Thank you! I know i'm picky but any help would be much appreciated!
Old Nov 8, 2015 | 11:03 PM
MNMLST's Avatar
MNMLST
16x8 et25
Lowered 1.75" front, 1.5" back.
DSC 1955
Old Nov 9, 2015 | 09:02 AM
Mega Babies
@MNMLST
What size wheels do you have?
Old Nov 9, 2015 | 06:53 PM
MNMLST's Avatar
MNMLST
Originally Posted by Mega Babies
@MNMLST
Like I said, 16x8. Tires you mean? 205/45
Old Nov 9, 2015 | 07:08 PM
Mega Babies
Oh yeah I meant tires, my apologies. Do you think 215/45 will fit?
Old Dec 9, 2015 | 02:13 PM
R53_Devin's Avatar
R53_Devin
MNMLST:
What type of wheels are those? Rotiform? What springs are you on?
Old Dec 9, 2015 | 08:31 PM
MNMLST's Avatar
MNMLST
3SDM 0.05 (Yes, "0.05" is what it's called. It's doesn't pertain to any measurement)
H&R Street Coilovers
Old Dec 11, 2015 | 12:56 AM
Nick Royer's Avatar
Nick Royer
I have 195/45/16 on my 3sdm's they are the perfect size for the 8 wides but very low profile
Old Jan 15, 2016 | 11:58 AM
Olly Cripps's Avatar
Olly Cripps
Hi guys I'm new here and actually from Essex in the UK
I have joined up because I came across this thread when searching for image of the 0.05 wheels on Minis! They do really look great and I've just got to have some lol.
@MNMLST @Nick Royer could you tell me what camber you're running on your rear wheels?
Also, guys over on the UK forum seem to all have 50 profile which looks a little chunky... so it's good to see some 45 business going on! Do you have any problems with your tyres?
Any other tips much appreciated.
Olly.
Old Jan 16, 2016 | 09:29 PM
MNMLST's Avatar
MNMLST
Originally Posted by Olly Cripps
...@MNMLST @Nick Royer could you tell me what camber you're running on your rear wheels?
Camber in the back is 3 degrees. At the moment, I'm not equipped to adjust camber at the front, which is stuck 1.7 degrees. I raised the front by .25 inch to avoid rubbing. Other than that, this setup is good a balance between ride comfort, style and performance. And these wheels are fantastic!
Old Jan 19, 2016 | 01:49 AM
Olly Cripps
Thanks for the reply! Wow 3° really, it doesn't look that extreme in your pictures. I hope you don't mind but I've emailed the above to a reseller I found in the UK for precisely the kind of look I want
It seems you're running standard wheel bolts too? That's good as most I've come across seem to have a stud conversion... not a problem in itself, but it's just added cost innit.
Old Mar 3, 2016 | 06:16 AM
Olly Cripps
That's great, thanks.
I am getting these put on next month now, with top mounts on the front and two sets of rear control arms on the rear so should get them sitting nicely! Unfortunately it's proving hard to get the (Michelin) tyres I want in 205/45... but I shall continue my search.
Got one more question regarding these particular wheels though. Do you know if they have a 60 degree tapered seat? If so then I can go ahead and order the wheel bolts I want
Old May 9, 2016 | 07:04 AM
Olly Cripps
Just thought I'd update this showing pictures of them now on my car. Ended up with 2.5° front and 4.0° rear camber...
Old Aug 28, 2017 | 08:04 AM
hunterrileyortiz's Avatar
hunterrileyortiz
16x8
Hey man I was wondering if you can help me because I have a r53 Mini and I want 16x8 with a 25mm offset and I have stock suspension. Do you think this will work or no
Attachment 143625
Attachment 143626
Attachment 143627
ey baby
Old Jul 12, 2018 | 01:50 PM
IDoSeaDoo's Avatar
IDoSeaDoo
could I run 205/45/16 on my stock height Clubman S with 16x8 et20 rims? I'm worried about rubbing and such... Also, will it be harder on the transmission? I know these will be slightly larger than stock.
Old Jul 13, 2018 | 03:49 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
205/45-16 is smaller diameter than stock. Stock 16 inch tire size is 195/55-16, and stock 17 inch tire size is 205/45-17. If you are still on stock suspension, you shouldn’t have any rubbing, but it will look funny...
JamesDeBart
Apr 16, 2016 05:00 PM
Alpha Motoring
Nov 10, 2015 07:08 AM
Oct 1, 2015 12:34 PM
Tires, Wheels & Brakes
Oct 1, 2015 12:18 PM
