R50/53 Newbie! 2003 Inde Blue Mini
Old Oct 5, 2015 | 02:49 PM
Blayne Wendland's Avatar
Blayne Wendland
Need help guys. have just finished putting in the new transmission. car runs fine. engine light is on, car will not move. any ideas?
Old Oct 6, 2015 | 06:25 AM
Spencer Roper's Avatar
Spencer Roper
Have you tried using a scan tool to see what the code is?
Is there fluid in the tranny?
Your question is so vague
Old Oct 6, 2015 | 08:58 AM
Blayne Wendland
sorry for being vague, tranny is full of fluid, EML light comes on for a second, Engine light stays on. Oil in car was changes. Tranny had Drive belt replaced. Everything is hooked up correctly. I heard about a fail safe mode for CVT Transmissions. I have owned a mini for a month now, already regretting it. lol, got the car cheap.
Using code reader i got a few codes , gas cap and a few others but none to do with the transmission. I did get one code i did not know "no SUP" The car starts asnd runs fine with no wierd noises from tranny, will shift but not move
Old Oct 6, 2015 | 09:10 AM
Blayne Wendland
codes are
P0455
P1787
P1741
P1698
Old Oct 6, 2015 | 09:27 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
P0455 here - Evaporative Emission Control System Leak Detected Gross Leak
P1787 & P1698 may be related to the transmission. Some good info HERE with a solution. Any time searching for P1787, code P1698 is listed along with it. Otherwise, if that solution doesn't work I also ran across some threads that said to check the battery as it could be the cause and it was for one individual.
P1741 - Clutch Solenoid Open Circuit
888.280.7799 | 6am - 5pm PST
Old Oct 6, 2015 | 09:44 AM
Blayne Wendland
Thanks, Ive cleaned the contacts with some electrical cleaner and NO ECU's.
http://www.minicarparts.net/PDF/MR5E...0825-234V1.pdf
car purrs like a kitten and for a second when i cranked it over it felt like it was pulling ahead but when it runs nothing? Do i have to train the transmission?
Old Oct 6, 2015 | 09:54 AM
PelicanParts.com
Vendor
Are you getting the xP or xD or xR on the display? I'd try to follow the steps given at post #3 at that link to see if it may at all help with your issue. Test the battery too, see what voltage it's reading.
Old Oct 6, 2015 | 10:02 AM
Blayne Wendland
Not getting the x in front, everything is looking good, will test the battery! I really appreciate your help!
Old Oct 6, 2015 | 10:14 AM
PelicanParts.com
Vendor
No problem! Wish I could be more helpful. I did find something where someone mentioned it could be a loose connector from the transmission. Thread here.
Old Oct 6, 2015 | 10:18 AM
Blayne Wendland
Ive cleaned the connectors and I am not getting any ecu codes im getting 12.5 volts on the bat
Old Oct 6, 2015 | 10:53 AM
PelicanParts.com
Vendor
I'm no expert on this so bare with me. Since it's a used transmission there is a possibility it could be a faulty part. Otherwise, if you had a similar issue to this before the install of the used transmission, maybe a fuse is blown that affects the solenoid..? If it is a new transmission you may still need to program/code it to the car. If you have the tools to do this, it may not be a bad idea to try. This is going off some BMW experience, but never did anything like this with a MINI. Make sure everything is connected to where it should. Sorry I can't be of much help, but hopefully someone else will chime in with some ideas.
Old Oct 6, 2015 | 11:02 AM
Blayne Wendland
I rebuilt the tranny by myself, chain was the only problem. if the parts are messed in the tranny shouldn't they show on the error codes? there are zero error codes showing after i cleaned the plugs that connect to the tranny. I also tightened the gas cap. No warning lights on the mini. At a loss
Old Oct 6, 2015 | 11:09 AM
PelicanParts.com
Vendor
It still may be worth a shot to reprogram the module. Were any faults present before the rebuild causing you to rebuild it?
Old Oct 6, 2015 | 11:50 AM
Blayne Wendland
i bought the car with the transmission not working. Engine is running fine, took the pan off and the drive belt was laying in the pan. took it apart, replaced the belt and installed
Old Oct 6, 2015 | 04:49 PM
Blayne Wendland
At my wits end, going to rip the tranny and tear apart again.
Old Oct 7, 2015 | 07:27 AM
PelicanParts.com
Vendor
One of my MINI specialists will be in tomorrow so I'll pick at his brain to see what other ideas he may have. In the mean time, let me know what you find.
Old Oct 7, 2015 | 12:49 PM
Blayne Wendland
I have found that the cable to the tranny has gotten bent during the tear out. I have a question. Should I be able to manually put it in gear without the cable to test the tranny?
Old Oct 9, 2015 | 10:31 AM
Blayne Wendland
I think that I may have solved my problem. found this laying on the floor gleaming in the sunlight.
tranny back on the ground. first tear out took 3 days, this one, 3 hours. What is the name of this piece?
chowpott
Oct 19, 2015 08:37 AM
navybsn
Oct 4, 2015 03:27 PM
Sep 30, 2015 11:39 AM
Sep 30, 2015 11:38 AM
dutchhome
Sep 30, 2015 07:17 AM
