R50/53 Drivers side wheel, 2 wires ?
Old Oct 3, 2015 | 01:34 PM
got_mini?'s Avatar
got_mini?
OKay was changing my outer tie rod today adn got confused.
I have two sets of wires or hoses i dunnno running to the drivers wheel.
One goes into the top of the hub which im assuming is my ABS.
I also have a set which is oddly hanging off my bleeder for my brakes?
What is this other one ?
Old Oct 3, 2015 | 01:37 PM
bavmotors's Avatar
bavmotors
Should also be a wire to the brake pad for the wear sensor
Old Oct 3, 2015 | 01:39 PM
Finhead's Avatar
Finhead
Yeah it's this guy, you'll need a new one or you'll have a pretty dash light.
https://www.ecstuning.com/Mini-2005-...nsors/ES61989/
Old Oct 3, 2015 | 01:44 PM
got_mini?'s Avatar
got_mini?
That would be it . .
Weird thing is its not connected and I dont have a light on ?...
Old Oct 3, 2015 | 01:50 PM
bavmotors's Avatar
bavmotors
Sometimes when being reused the sensor won't stay in, or they just come disconnected. The light will only come on I believe, if contact worn into.
Old Oct 3, 2015 | 01:51 PM
Capt_bj's Avatar
Capt_bj
If you remove a worn sensor and don't replace you continue to get the light, jumper it and the computer 'sees' a new sensor
the way to jumper out the sensor is to cut the end off and connect the two ends together allowing the computer to 'see' a completed circuit, then you just tuck/tie the wire out of the way.
Some folks think the sensors are not worth a dime so jumper and tuck
on my 7, sensor snipped off, wires soldered and shrink wrapped:
SENSORS ..... we don't need no damn sensors! HaHaHaHaHa
If you find such a wire to nowhere and you trace back and REMOVE it from the connector .... the computer will see an open circuit which = WORN SENSOR and the light comes on . . .
Old Oct 3, 2015 | 01:52 PM
cerenkov's Avatar
cerenkov
The sensor will only give a light if it is activated, i.e. wore down.
Old Oct 5, 2015 | 10:16 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Yep, there is one brake pad wear sensor and it is on the front left wheel. 34-35-6-778-175 here is fairly inexpensive and not a bad idea to replace when you do your brakes. Some good info and how to remove/install it here.
888.280.7799 | 6am - 5pm PST
Old Oct 5, 2015 | 12:10 PM
ZippyNH's Avatar
ZippyNH
On a gen1 the only way it turns on is if the electrical connection is severed...so a cutvwire, or a worn sensor, aka a cut wire at the pad will turn on the light...
There is no impedance change detection to give % wear on the gen1 cars...gen2 car do this..sorta...that is why it is easy to jumper the gen1 or reuse the sensor...
Doc Pain
Mar 10, 2021 04:50 AM
freeman727
Dec 10, 2017 04:00 AM
pbkirby
Oct 4, 2015 06:02 AM
Oct 1, 2015 12:13 PM
pkillur
Tires, Wheels, & Brakes
Oct 1, 2015 03:59 AM
