R56 Consequences of a DP CEL?
Old Sep 29, 2015 | 09:27 PM
potterstein's Avatar
potterstein
I have to change my oil filter housing gaskets, so i figured now is a good time to upgrade the DP as long as i'm in there.
Thinking I'll be going with this DP, as Way has quite a following here on NAM, and the price seems right.
http://www.waymotorworks.com/wmw-cat...8-r59-r60.html
I plan on getting a Manic tune somewhere down the road when the funds present themselves, but until then...is it just an annoying yellow CEL, or is it an annoying limp mode CEL?
Thanks!
Old Sep 30, 2015 | 12:21 AM
GEMSTER's Avatar
GEMSTER
Its just a light on the dash. No limp mode.
Old Sep 30, 2015 | 05:47 AM
GAT's Avatar
GAT
Thanks!
Don't quote me on this but if I recall correctly, WMW offers some sort of plug-n-play component specifically made to eliminate the DP CEL. I think it was in the $100-$200 range. Always an option if you can't wait until your Manic tune.
Old Sep 30, 2015 | 06:16 AM
JohnDoe11's Avatar
JohnDoe11
I recently installed a DP and the CEL came on after 200 miles.
Other than the code and another 100 miles the cars running great and sounds great.
To get ride of the CEL I just use my obd2 and clear the codes and I'll wait out to see when I'd have to do it again.
Old Sep 30, 2015 | 08:27 AM
Rick.Astley's Avatar
Rick.Astley
Just a CEL - depending on where you are, it may just be an inconvenience during smog. Plenty of Mini folks run them.
Old Sep 30, 2015 | 10:59 AM
potterstein
Well this is all very good news Looks like this plan is a green light.
Old Sep 30, 2015 | 09:12 PM
Systemlord's Avatar
Systemlord
A tune is the only way to eliminate a CEL, the plug-in-play device you're referring to doesn't prevent the ECU from registering the CEL, you just won't get the yellow light on your speedometer.
Old Sep 30, 2015 | 10:50 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Consequences of a catless DP?
1) even if you turn off the CEL with a tune, you'll NEVER pass an emissions test. Looks like AZ requires testing every 2 years. Good luck with that.
2) More smog for everyone to breathe.
OK I'll go back under my bridge now.
Old Oct 1, 2015 | 06:27 PM
potterstein
I suppose having to swap the stock DP back on every 2 years may be a bit of a hassle...but when you think about how AWESOME A CATLESS DP AND TUNE IS...not that big a deal.
As far as smog is concerned...lol. Drive an electric car you dirty hippy!
Old Oct 1, 2015 | 06:42 PM
Systemlord's Avatar
Systemlord
Name calling like that won't get you very far on NAM, but you did ask about the consequences of running a DP.
Old Oct 1, 2015 | 07:03 PM
potterstein
He literally implied he was a troll. I can't poke a little?
Old Oct 1, 2015 | 07:37 PM
squawSkiBum
Moderator
Ever driven a Tesla Model S dual motor set to Insane mode? I have. Now THAT is awesome, not a little 4 banger spewing hydrocarbons and NOx because the cat was removed to gain a few HP. And wouldn't that be clean hippy?
You did ask about the consequences. I have another thread somewhere about the legal, environmental, and ethical issues of deleting your catalytic converter. Look it up if you're interested.
Old Oct 1, 2015 | 07:49 PM
potterstein
I have been on a ride along, and yes, they are quite thrilling.
I apologize for responding to your snide comment (see: "good luck with that") with sarcasm.
If a mod would like to delete this thread, I wouldnt mind. Seems a bit off topic now anyway.
Old Oct 1, 2015 | 09:05 PM
squawSkiBum
Moderator
No worries. We all need to keep a sense of humor, and I have been called far worse things.
Old Oct 1, 2015 | 09:07 PM
wzabrouski's Avatar
wzabrouski
The akrapovic delete r also block every CEL code.
Old Oct 2, 2015 | 05:05 AM
Joeygonz's Avatar
Joeygonz
Akra delete r is good but a little pricey for its purpose.
How about BMWhat App? For $40, it can suppress codes until a tune is installed and later on can also be used for some diagnostics and some coding?
Old Oct 2, 2015 | 09:30 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
BMWhat or Carly as its called now doesn't suppress the CEL but it will clear the code and extinguishes the light. At least until the ECU runs the cat test twice and fails. Then the light will be back. Lather, Rinse, Repeat...
neezebeeze
Oct 31, 2016 12:10 PM
rob&JCW
Oct 9, 2015 11:12 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
cguzz
Sep 20, 2015 03:42 PM
Nick Royer
Sep 16, 2015 08:17 AM
