R56 Low on coolant - 2010
Old Sep 8, 2015 | 04:54 PM
debitsandcredits's Avatar
debitsandcredits
Hey all,
Over the holiday weekend I noticed a problem with my Mini (2010 base, 77K Miles) and I'm concerned and confused a bit. I noticed that my coolant was low (a half inch below the minimum mark). I added coolant to fill up to the max line, but now I'm back at the minimum mark (3 days have passed.)
I did some research and checked my oil, no yellowness/cloudiness (oil was actually a little low, which surprised me).
I checked my parking spot for leak spots, but didn't notice any there either.
After minimal online research, I found that the first gen Minis had leaks at the themostat housing, but I'm not sure how prevalent this was for the second gen.
I plan on taking it in for a pressure test at my local shop, but I wanted to ask if anyone here has experienced such a problem or can give me an idea as to what I can expect.
Thanks!
Old Sep 8, 2015 | 05:08 PM
gjxj's Avatar
gjxj
thermostat housing is a common issue on gen ii as well.
Old Sep 8, 2015 | 05:14 PM
debitsandcredits
Lovely, any idea on price for a repair?
Old Sep 10, 2015 | 09:17 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Check the thermostat and see if you can find any type of signs of leakage somewhere. Coolant can be leaking and possibly pooling on top of the transmission. I've seen people replacing theirs on their R56 as soon as 50k miles. Once you determine it's your issue, if you're DIY handy, thermostat can be purchased here. Here is a DIY on the replacement. A video at post #164 may be helpful too.
888.280.7799 | 6am - 5pm PST
Old Sep 10, 2015 | 11:26 AM
Here some info on the thermostat housing :
https://www.northamericanmotoring.co...8-no-heat.html
The coolant will pool on top of the transmission housing sometimes and you will not see it.
For the " Cooper " Models you will not have the aux water pump.
Also on 6/2010 to 3/2012 Gen 2 MINI Cooper ( NON S ) you will have the additional adpater lead.
https://www.northamericanmotoring.co...out-where.html
If you need else let me know.
Old Sep 10, 2015 | 04:22 PM
tylewis's Avatar
tylewis
If you are handy then try your hand at replacing it yourself. I had the issue and would have liked to do it myself but it was over my head. The part itself was about 129 and the labor was around 500. Maybe I got ripped off but the guys told me it took them all afternoon and after looking at some information about DIY, I believed them. My check engine for this came on around 51000 miles.
Old Sep 17, 2015 | 11:56 AM
debitsandcredits
Well, I got a pressure test done today, but they said they could find no leaks and held pressure fine. I'm stumped.
I did notice that the coolant level was significantly higher when I got the car back, but the mechanic said he didn't add any. I'm hoping it just needs to settle.
Old Sep 18, 2015 | 08:36 AM
I guess I would blead the coolant system and see if you have a build up of an air pocket somewhere. The coolant level should stay the same from Cold to Cold , now if you are looking at it hot then cold the level changes.
Old Sep 18, 2015 | 09:34 PM
debitsandcredits
Thanks ECST, I'm curious, how would an air pocket hide somewhere? Wouldnt it get worked through somewhat quickly? I'm not familiar with cooling systems, so please forgive the question.
Old Sep 21, 2015 | 06:47 AM
I have seen it after a thermostat housing change coolant system work. You have to bleed and rebleed the system. I bled mine like 3 times after a thermostat change.
Old Sep 21, 2015 | 07:47 AM
debitsandcredits
Won't any air in the system escape on its own via the overfill tank?
Old Sep 21, 2015 | 08:18 AM
PelicanParts.com
Vendor
Trapped air is common when filling a cooling system and can result in improper cooling. It is important to bleed your cooling system each time the cooling system is serviced. The overflow tank isn't the highest point in the system, so until you bleed the system it wont just escape.
Old Sep 21, 2015 | 08:26 AM
debitsandcredits
Excellent, thank you for the help!
Old Sep 21, 2015 | 08:28 AM
It will need bled at the screw near the thermostat housing to get all the trapped air out.
Old Sep 21, 2015 | 08:34 AM
PelicanParts.com
Vendor
You're very welcome. If you need anything, don't hesitate to ask me.
potterstein
Dec 30, 2024 05:18 PM
CardinalsRule
Jun 11, 2016 04:34 PM
wesmc
R55 :: Clubman Talk (2008+)
Sep 28, 2015 12:07 PM
tylewis
Sep 6, 2015 01:07 PM
potterstein
Sep 4, 2015 09:52 AM
