Horrific and sudden noise from all speakers.
Old Sep 3, 2015 | 05:55 PM
lweaver's Avatar
lweaver
Hello! Hoping someone can provide insight into a jarring experience I just had in my 2010 cooper hardtop with a Harmon Kardon stereo system. Driving down a road in the rain, my stereo suddenly began making horrific feedback noises and scratching static at max volume and did not respond to inputs (including attempting to turn the stereo completely off). I legitimately thought the car had been struck by lightning.
The noise settled on a a high pitch squeal so incredibly loud that I had to turn my hazards on, pull over, and exit the car. The noise continued for several minutes after I removed the key from the ignition, and it sounded like other electrical systems may have also been malfunctioning (there are several electric motor type noises I hear on a regular basis that sounded similar to what I was hearing, but these were ).
It eventually stopped and I got it home without the noise returning, but now I'm very worried that it will happen again. Is there a fuse I can pull until I get it to the dealership? I am out of warranty, unfortunately, and I read somewhere that even checking the internal stereo fuse is hours of labor...
Old Sep 3, 2015 | 08:22 PM
chrisfowler99's Avatar
chrisfowler99
I had the same issue about six months ago.
https://www.northamericanmotoring.co...rive-home.html
It only happened that one time.
You're the first I've seen with the same issue...
Old Sep 3, 2015 | 09:01 PM
lweaver's Avatar
lweaver
Hmmm. That's a little unnerving. Have you had any other electrical issues in the interim? This noise literally sounded like the car being violently torn apart.
I guess I'll just continue to drive it and throw some earplugs in the cup holder...
Old Sep 4, 2015 | 04:06 AM
Drivehard's Avatar
Drivehard
If I recall HK amp is under front seat. Check for wetness or even a rogue water bottle wetting electronics I think amp is under passenger seat but not sure. May want to check connectors on amp also
Sent from my iPad using NAMotoring
Old Sep 6, 2015 | 12:28 AM
Systemlord's Avatar
Systemlord
I'm sorry I couldn't help myself.
"Their here", unlike a haunting it only gets worse. Stay away from the static and I think you'll be alright.
Attached Thumbnails Horrific and sudden noise from all speakers.-poltergeist-original.jpg
Old Sep 11, 2015 | 05:37 AM
Heard this on the Gen 1 MINI with H/K , the amp is in the back rear , in the trunk under the side carpet. Is it a loud beep for a second ?
Old Sep 11, 2015 | 10:43 AM
Systemlord's Avatar
Systemlord
Aren't the HK amps known to fail in this manner? This isn't the first thread about failing HK amps and member's looking for a replacement.
Old Sep 11, 2015 | 10:48 AM
Yes,
I had mine beep about 9 times on very hot days and still going strong , others had it beep once and die. Most people get the beep a couple times and then its dead. The heat kills them.
I swear its like 160 db beep. Scares the crap out of people and myself. If the Gen 2 is like this , bet the amp overheated. They dont have fans like the BMW individual system amps, i think thats the issuse.
Old Sep 11, 2015 | 11:23 AM
Systemlord's Avatar
Systemlord
Yes,
No fans, that's a insanely poor design destined to fail, doesn't the HK amp fit underneath the heated seats?
Old Sep 11, 2015 | 11:46 AM
The R52 HK amp is under the seat, R53 HK amp in the trunk and R56 HK amp in the trunk.
R57 HK amp under the seat :
https://www.northamericanmotoring.co...-problems.html
https://www.northamericanmotoring.co...-kardon-4.html
Unless I am missing something.
Old Sep 24, 2019 | 05:03 AM
Loriann Neighbors's Avatar
Loriann Neighbors
I just experienced the same horrific noise! Radio off, yet it is screaming at me with alien sounds, high pitch beeps, etc. Happened yesterday, then blissfully stopped. Then got in the car this morning and it started up again. I'll check with the dealer but do know that you are not alone- and it appears I am not alone either!
Old Mar 3, 2020 | 01:40 PM
Eyeball B's Avatar
Eyeball B
Thank goodness for this thread. 2006, manual R-53. Just happened to me yesterday. I had the stereo on low, heading to the gas station because less than a quarter of a tank (low fuel red light indicator was on), and BEEP! Exactly how previous posters described. Ear piercing, half second tone, coming through the speakers. So loud my ears were ringing for about a minute afterwords. More than annoying it actually seems harmful. Hopefully it will be a long time before it happens agains.
Old Mar 4, 2020 | 12:50 PM
yep, it happens. They might say deal with it or replace the amp.
Old Aug 22, 2020 | 08:45 AM
Sandi Clausen's Avatar
Sandi Clausen
Sounded like explosions all around me
My mini did this a few years back and then stopped in a few days. Thought a speaker finally popped. Today I open the door not even having the keys and it started again! It is such a horrific noise
Old Aug 25, 2020 | 01:03 PM
maegan D-N's Avatar
maegan D-N
Solution? I have a R53 Harmon Kardon system doing the same
did you find a solution to this? Or is the only solution to replace the amp Mine is under passenger side seat I don't think I can bare hearing that noise again.
Old Feb 10, 2021 | 04:42 PM
ahsram5's Avatar
ahsram5
Guess this thread's pretty old, but...if anyone's following & had this issue resolved, plz share details? My experience was just like orig poster, lweaver.
Raining, God-awful, loud, crackling sounds. Had no idea what it was. Thought maybe a drive-by & sunroof. or windows were shattering. Pulled into nrby gas station, got out & away frm Mini. (2010 Hard-Top S). Thought explosion was coming! Didn't hear any beeps. Very nice guy in a service truck came over, checked it out, said maybe short in a speaker wire & removed a fuse. Been driving it that way, no fuse, no stereo. Fuse only seems to be related to stereo, seatbelt warning & intuitive rear-view mirror lighting.
It's in shop now...would be great to know how other's resolved this.
Old Feb 10, 2021 | 04:55 PM
ahsram5's Avatar
ahsram5
Re: 'Horrific and sudden noise from all speakers'
...If anyone's still following this thread;
It's in shop now...would be great to know how others resolved this.
'Navin R. Johnson', "...he HATES these cans! Stay away from the cans"!
Old Mar 8, 2022 | 03:27 AM
MrHippo's Avatar
MrHippo
2021 Mini Countryman horrific noise
I am in the UK and thanks to everyone for posting to this thread, this has just happened to me, moved the car 10 feet on the driveway and the speakers blasted out at full volume this squealing noise.
My local dealer is going to look at the problem but now I have some idea what it is I can tell them to focus on the amp.
I may take some ear protection with me in case it happens again while I am driving.
Old Jun 28, 2022 | 01:46 PM
USNAE2's Avatar
USNAE2
Veteran: Navy
My R53 had incredibly LOUD Static noise with barely audible music underneath. It would go away for a while then come back (kind of like when it heated up from use) but then, it didn't matter how long it was off...turn on and SCREEEESHHHHH! Replaced with a known good H/K amp and all good. I have my former co-worker who still has all of the scopes and P/S to play with my bad amp and a dead one I procured. Hopefully, he can get them up in a short time and I'll have spares or refurbs for sale with core exchange.
Old Sep 17, 2024 | 08:22 AM
knightlight's Avatar
knightlight
Figured it out.
no inputs work either here when it happens. I did find what does work though, I accidentally turned the volume down when I went to turn it off and noticed that's how. The fricking volume I don't know how to fix it yet, but I may post back when I figure it out.
wow
Mitchell
chisss
23
Jul 27, 2021 03:25 PM
Calyman24
Mar 7, 2016 09:27 AM
A.J
Nov 11, 2013 08:40 AM
lilgrasshopper
May 4, 2009 10:28 AM
