R56 Mirror Gasket (weather seal?)
Old Sep 3, 2015 | 01:09 AM
potterstein's Avatar
potterstein
Greetings all,
I've got a 2009 Cooper S in Phoenix, AZ. Apparently the mirror gaskets dont hold up very well against 6 summers in 115F+ weather.
I called the dealership out here and they won't sell me the gasket by itself, i'd have to buy the whole mirror for the low low price of 195 each. I was able to find the r53 gaskets for $8 each...no such luck for the r56.
If anyone has any leads on where I could purchase some new ones, or even how i could make my own, i would be infinitely grateful.
Old Sep 4, 2015 | 02:02 PM
Systemlord's Avatar
Systemlord
The manufactures do this on purpose so you have to spend more money to replace parts, it's how they make their money. I had to spend almost $300 to replace my antenna mount because the rubber seal was starting to go bad, there is no cheap way out period. I know exactly what your talking about because for 25 years in a row I would go to Lake Havasu when it was 115F+!
Old Sep 4, 2015 | 02:27 PM
Slave to Felines's Avatar
Slave to Felines
Any idea what the gasket looked like when it was whole? You may be able to get some material (neoprene?) from a hardware store, or gasket material from an auto-parts store, and cut one to fit.
I've done that for paper gaskets before, and for rubber spacer blocks. Never a rubber/plastic gasket so far, but ...
If the shape is complex and 3D, that may not be an option. Unless you're willing to build the 3D shape out of layers of material.
Old Feb 22, 2016 | 07:44 PM
OxyBlue07's Avatar
OxyBlue07
Originally Posted by potterstein
Greetings all,
I had the same issue due to the extreme temperatures, but I just fixed it. I got the peice here: https://www.ecstuning.com/Search/SiteSearch/Mirror_Gasket/ES83238/
It says they're OEM, and that they fit for all models. Unfortunately, I did have to force the rubber to fit. I have the R56 model. Despite that, it looks like brand new and I'm happy with the results. It took me about an hour to do both gaskets.
Old Feb 23, 2016 | 05:02 AM
ES#83238 and ES#83237, is for the R50 R52 R53 models, there is a bug we are working on with the fits section on some parts. Please use the drop down menu for your model to get the correct parts. There is no separated part number for the R56- R59 mirror gasket. Its part of the whole mirror assembly. But looks like you found a part from the Gen 1 to fit gen 2 , congrats on the OEM mod. First time I have heard this works, do you have pics ?
https://www.ecstuning.com/Mini-2007-Cooper-R56-Base-Coupe-L4_1.6L_N12B16A/Exterior/Mirrors/4
Update***
We added some aftermarket options for the R55-R61 MINIs, direct fit and direct copy of the gasket on those models.
Left
https://www.ecstuning.com/b-bremmen-...167261775~brp/
Right
https://www.ecstuning.com/b-bremmen-...167261776~brp/
Old Feb 23, 2016 | 07:38 AM
OxyBlue07's Avatar
OxyBlue07
Thanks for the reply, ECS tuning! I definitely should have used that search tool; however, it does say that it fits all models on the site.
Even though it's not the right part, I still managed to make it fit! It's not perfect, but it does the job and it looks pretty good. Here's the results:
If you look closely, you can see where the old rubber was. I have to clean it a little more, but I just did it last night and I couldn't see what I was doing anymore, lol!
Old Feb 23, 2016 | 08:01 AM
Yep,
Thanks for letting us know. At least it was a chance that worked, and now we know it does.
With a little elbow grease and some rubbing compound that should come off.
Old Feb 23, 2016 | 08:09 AM
OxyBlue07's Avatar
OxyBlue07
Definitely! Thanks for the great parts and advice
Old Feb 23, 2016 | 08:24 AM
You are welcome. Always here to help,. meguires rubbing compound works good, so does the sonax and chemical guys stuff, but its more for deeper scratches.
https://www.ecstuning.com/Mini-2007-Cooper-R56-S-Coupe-L4_1.6L_N14B16A/Car_Care/Exterior/Polish_-and-_Paint_Correction/
Old Feb 23, 2016 | 12:00 PM
OxyBlue07's Avatar
OxyBlue07
Great, I'll check those out!
Old Feb 23, 2016 | 12:06 PM
Welcome.
Old Dec 30, 2024 | 05:18 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
I just went through this. I purchased the Gen1 gasket set through ECS Tuning, they can be made to work but they require some modification with a razor blade and don't fit that well. Google to the rescue - search for "Mini R56 side mirror gasket" and a bunch of aftermarket options come up, including through Out Motoring and Amazon.
texasmontego
Sep 19, 2019 05:15 PM
potterstein
Sep 4, 2015 01:30 PM
potterstein
Sep 4, 2015 09:52 AM
GreekDrifter91
Jul 13, 2013 04:42 AM
thecanuck
Sep 15, 2010 07:18 PM
