R56 Aftermarket BOV for r56
Old Aug 27, 2015 | 12:41 PM
MasterShaftner's Avatar
MasterShaftner
i think I need to buy I new BOV for my car it keeps bringing up the check engine light with a code about the BOV...
I need to know if there are any BOVs I could buy that won't lower my mpg or empty my wallets
Old Aug 29, 2015 | 01:51 PM
itsbrianyo's Avatar
itsbrianyo
save your money and stay away from any universal or the fancy BOV's that vent to atmosphere as they'll likely cause a CEL.
WayMotors sells a very good replacement here...
http://www.waymotorworks.com/wmw-per...off-valve.html
and you can pair it nicely with Altas spring for a little more pep...
http://altaperformance.com/i-1400716...bo-engine.html
Old Mar 27, 2016 | 07:00 AM
GrayGhost's Avatar
GrayGhost
Are you saying to replace the spring that comes with in the WMW BOV valve?
Old Oct 30, 2016 | 05:56 PM
mikeBURRITO's Avatar
mikeBURRITO
i recommend going with the forge product. it's a little more expensive but worth it in my opinion. but i like the sound of the Gredy type S.... but i have never seen anyone install on. would definitely like to see that because i want to know how they take care of the plug doing to the DV.
this is a little video i made a while back
Old Oct 31, 2016 | 04:21 AM
D1QuickSilver's Avatar
D1QuickSilver
I vent to atmosphere and I am not throwing a CEL.
Based on my research venting to atmosphere does not cause a CEL on the R56.
Old Nov 3, 2016 | 05:37 PM
Kalibdor's Avatar
Kalibdor
I went through 3 different types of vta bov's before I returned to a recirc valve. I've heard of people having issues with both the n14 and n18 platforms, but heard just as many people that never have a problem with vta valves. All I know is for me vta valves would cause CEL's and throw the car into limp mode. The most common issue was under light lift, the vta valve would release when the dv did not, and the car would see a leak in the system and freak out. I never tried the valves like the forge vta which replaces the dv entirely, however, so maybe that's the fix. Regardless, there is zero benefit of a vta valve on these cars; they were designed as internal recirc and in my opinion should stay that way. But if the sound is all you want, go for it. As for recirc valves, the one Way sells is great, and if you want a step up from that, or if you plan on tuning and running higher boost I'd recommend you save up and buy the Forge recirc.
Old Nov 4, 2016 | 01:19 AM
BigBoost's Avatar
BigBoost
Check out the turbosmart kompact vavle !
Old Nov 4, 2016 | 01:20 AM
BigBoost's Avatar
BigBoost
http://www.turbosmartdirect.com/Prod...Dual-Port.html
Old Nov 4, 2016 | 09:38 AM
nkfry's Avatar
nkfry
The Forge units are a great replacement, I've only had to warranty one unit out in over 3 years.
The rebuilt factory units are the ones that I see more problems with, but if you don't want to spend the money on a Forge unit, I'd just recommend the updated MINI unit.
Forge BOV N14
Forge BOV N18
MINI Diverter Valve
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
jaydeeps
Dec 8, 2015 09:13 PM
theunlimitedone
Aug 31, 2015 08:17 PM
1chaos52
Aug 24, 2015 01:28 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
