JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Installed OEM GP rear diffuser
Old Aug 25, 2015 | 10:32 PM
minimofo's Avatar
minimofo
Installed the OEM GP diffuser today. This is a straight forward mod, and I figured out how to easily remove the 2 torx screws from the ends of the stock JCW rear bumper center section. Snap out the 2 corner black trims but don't remove. That gives you enough room to use a torx driver. Reverse when installing the new diffuser.
I haven't driven at high speed yet to tell the difference but sure look pretty cool and aggressive. I believe it completes the JCW look very well.
Old Aug 26, 2015 | 04:28 AM
Drivehard's Avatar
Drivehard
NICE! Yes really befitting the car
What do you mean by what you said about the 2 hard to reach torx? I know they are hard to get to but please explain.
Sent from my iPad using NAMotoring
Old Aug 26, 2015 | 07:08 AM
TrueEddie's Avatar
TrueEddie
Looks good
Old Aug 26, 2015 | 01:30 PM
minimofo's Avatar
minimofo
at the ends of the stock center bumper piece (1st pic), there are 2 t25 torx screws that attach it to the bumper itself. if you look closely at the 1st pic, you'll see the black trimming on the bumper that are slightly detached from the bumper. that's how i got to the 1 torx screws to get them out. otherwise they're behind the bumper at an angle such that you can't put a long screwdriver in to get them.
those 2 t25 torx screws are reused with the new/gp diffuser. that's really the hardest part of this install. i've circled the 2 locations where the 2 screws are in this pic below.
Old Aug 27, 2015 | 09:46 AM
Grizld700's Avatar
Grizld700
Looks good! I installed this with my Aero Kit. I was cheap and did just the outer trim piece and not the actual diffuser parts. I wasn't sure I'd actually feel a difference from them.
Old Aug 27, 2015 | 10:01 AM
ATCQL's Avatar
ATCQL
I like the look with the white paint. Mine is installed on a 13 coupe, which is red and painted to match the body. If interested look at my gallery for a different look. Q
Old Aug 27, 2015 | 04:37 PM
minimofo's Avatar
minimofo
I was thinking about having the top side/surface painted chilli pepper red to match the car's roof and leave the bottom side matte black. Yes, I think I saw yours and was my inspiration. Still debating it though.
I will have the Orranje GP wing's horizontal slat painted chilli pepper red and vertical legs gloss black to blend in with the glass so to speak...when it arrives mid-September.
Old Aug 27, 2015 | 06:18 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Looks great, we've installed about a dozen of them and it always turns out great.
Old Aug 27, 2015 | 07:10 PM
minimofo's Avatar
minimofo
The only problem I have which isn't major - diffuser came missing the 4 screws (2 per side) at leading edge/aluminum end that attaches with the belly pan and 1 screw that attaches the left side of the center panel. These are not major and over to the dealer to grab the missing screws.
Old Sep 9, 2015 | 02:43 PM
1guru2's Avatar
1guru2
Now, top it off with the GP2 engine under tray. Having the under panels and diffusers is like having a wing with no leading edge. The louvers in the engine under tray help direct the air coming through the intercooler. That was one of the reasons for it on the GP2. I have all 3 on my 2013 JCW Hardtop. I can tell the difference, especially in a crosswind. It makes the car feel real solid @ 80 (only in Utah on I-15 and I-70). Easy to install once you get the clips pressed in the frame. Did it in my driveway on jack stands. Oh, bought mine at Way Motors!
Old Sep 9, 2015 | 04:51 PM
minimofo's Avatar
minimofo
Thanks for the info. I'll look into it. Not bad for $300 or so.
Old Sep 10, 2015 | 09:28 AM
minimofo's Avatar
minimofo
Btw you mentioned you "have all 3". What's the 3rd part if you also have the diffuser and belly pan?
Old Sep 10, 2015 | 09:52 AM
Grizld700's Avatar
Grizld700
I think 1guru2 is refering to the underbody panels. Your JCW probably came with these panels, but not all did as they were developed later.
Old Sep 10, 2015 | 03:50 PM
minimofo's Avatar
minimofo
Ok, my underbody panels are flat between the axles. I have no belly pan under the engine.
Old Sep 10, 2015 | 10:08 PM
1guru2's Avatar
1guru2
Ok, to clear this up. My 2013 JCW Hardtop came with the flat under trays. First I added the rear diffusers, bought thru MINI. Later on I added what I call the engine under tray. I bought that from Way Motors, but it has the MINI part # on it that came on the GP2's. Like I said earlier having the flat under trays and diffusers without the engine under tray is like having a wing with no leading edge on it. It is needed to direct the airflow to the under trays and diffuser. It all works together. I tested it with my leaf blower. Old men have too much time on their hands! LOL
Old Sep 11, 2015 | 04:54 AM
RDSJCW's Avatar
RDSJCW
Will the diffuser fit on a 2016 JCW hatch?
thxs Rich
Old Sep 11, 2015 | 09:20 AM
Grizld700's Avatar
Grizld700
Different rear bumper all together RDSJCW. I will not fit without major custom construction.
Old Sep 11, 2015 | 10:17 AM
RDSJCW's Avatar
RDSJCW
ok- bumma.
thxs anyway.
Old Sep 11, 2015 | 11:49 AM
mct's Avatar
mct
Originally Posted by RDSJCW
ok- bumma.
thxs anyway.
The part number for the diffuser for the 2016 JCW rear bumper is "51192339046". It is slightly different styling, but still looks ok.
Old Sep 12, 2015 | 04:52 AM
RDSJCW's Avatar
RDSJCW
ok- great.
where to buy it & see it?
thxs Rich
Old Sep 12, 2015 | 09:36 AM
Grizld700's Avatar
Grizld700
Copy the part number and go to http://www.ecstuning.com/ and paste it in the search bar. It will pop up with pics, description, and price.
Old Sep 14, 2015 | 05:58 AM
Gen 3 F56 Version Here :
With PDC
51192339046
Without PDC 51192339047
https://www.ecstuning.com/Search/SiteSearch/51192339047/
And the Gen 2 R56- R59 Version here 51747330558 KT
http://www.ecstuning.com/Search/SiteSearch/51747330558KT/
Old Sep 14, 2015 | 06:11 AM
RDSJCW's Avatar
RDSJCW
Nice- thanks,
Waymotorworks has the JCW pro front splitter part #51192339038 for $349.00 free shipping. ECS price is $412.00. Can you match?
Regards Rich
Old Oct 25, 2015 | 05:53 PM
isamin's Avatar
isamin
Follow a JCW with these parts on a rainy day if you have any questions about how well they work.
ISAMIN
minimofo
Factory JCW Talk (2009+)
130
Oct 14, 2016 06:14 AM
blackie
Oct 2, 2015 07:41 PM
squawSkiBum
Oct 2, 2015 09:21 AM
FLYM1N1
Aug 16, 2015 01:15 PM
