R56 Eibach Lowering Springs
Old Aug 5, 2015 | 07:43 PM
jeremy_reyes94's Avatar
jeremy_reyes94
Hi guys, thinking about putting Eibach lowering springs on my 2008 r56 that just hit 99k, any pros and cons? Do the struts wear out fast? Please helps
Old Aug 5, 2015 | 09:16 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
They work but you loose a lot of shock travel so the ride can be harsher.
http://www.waymotorworks.com/eibach-...g-springs.html
Old Oct 16, 2018 | 12:54 PM
damnitdanny's Avatar
damnitdanny
Has anyone tried the Megan Lowering Springs .5" Front, .75" Rear? I want to get a better looking stance but don't want to go "to low". Also would I have to change the rear lower control arms?
Thanks,
Old Oct 16, 2018 | 05:04 PM
tman's Avatar
tman
I have eibach springs on my '11 S. It rides nice and stiff, rear was higher than front so I cut one coil off the springs.
It's pretty level now and still rides fine.
It is definitely not too low, I have no trouble with speed bumps or rubbing.
I did get adjustable rear control arms to get the camber right.
Old Oct 21, 2018 | 11:15 AM
Milos1980's Avatar
Milos1980
Eibach prokit on my cooper. Perfect ride height for me.
Old Oct 30, 2018 | 02:28 PM
damnitdanny
Very Nice!
Old Jul 5, 2019 | 12:00 PM
F1 Fanatic's Avatar
F1 Fanatic
If the Eibachs drops the same as Nm springs by 1.2”, how can the Eibach springs lose suspension travel and be harsher in ride, yet the Nm springs have a higher spring rate than the Eibachs (I.e firmer) so wouldn’t the Nm also suffer from suspension travel also, if not worse?
Old Jul 8, 2019 | 02:43 PM
Kevinp_27's Avatar
Kevinp_27
I have swift springs with 15mm spacers
Old Aug 4, 2019 | 08:34 PM
Timbo14's Avatar
Timbo14
My PS
Old Aug 16, 2019 | 05:12 PM
MiniSJCW's Avatar
MiniSJCW
I’m in the search for lowering springs for my 2013 S. I think that both the Eibach and the H&R springs would lower the car too much.
i I also want to get better handling and look. I’m going to look at the Megan springs. I did some measuring today to determine how much clearance there
is with the stock springs. I also installed Koni yellows last winter and they helped with the handling.
I had a Mustang
Cobra at one point and it was lowered too much and I experienced rubbing. Not a happy thing!
Old Aug 16, 2019 | 05:38 PM
MiniSJCW's Avatar
MiniSJCW
How much clearance between the tire and your fender do you have with the lowering springs??
Old Aug 17, 2019 | 04:48 PM
MiniSJCW's Avatar
MiniSJCW
How much clearance do you have now? Any rubbing?
Thank you
Old Aug 27, 2019 | 07:03 AM
KCLARK's Avatar
KCLARK
I have some eibachs that's for a convertible and my car is a hardtop. Does anyone know if putting these on will work?
I'm wondering if the spring rate for the rears is higher since convertibles have more weight in the rear which I'm thinking would cause the springs to be stiffer and prevent sag.
Old Sep 6, 2019 | 07:53 AM
Stefano Tefi's Avatar
Stefano Tefi
Mini r53 stance 18
mini r53 stance 18
mini_mike237
16
Jan 30, 2024 11:20 AM
MattsMini2006
Jul 16, 2014 02:41 PM
kaseyb
May 4, 2011 03:39 PM
Striped Toad
Suspension
Jul 14, 2008 02:24 PM
neilgj
Suspension
Feb 8, 2006 03:49 PM
