Countryman Rear Caliper Dust Boot Torn
Old Jul 26, 2015 | 06:18 PM
camucho's Avatar
camucho
I was compressing the rear piston and the dust boot was torn. Is there a way to fix it? I checked RealOEM and it shows the caliper housing as a unit.
The piece I'm referring to, is the rubber boot that protects the piston from dust and debris.
Any ideas?
Thank you
Old Jul 26, 2015 | 10:55 PM
S4SF's Avatar
S4SF
If it were my car I'd remove the piston to inspect for scratches. What you want to look for is a caliper rebuild kit from the dealer. Do not compromise safety for a $5 difference in an aftermarket seal. It should have the square piston seal and dust boot, but confirm that it has both. If you're not 100% confident in rebuilding a caliper, PAY SOMEONE TO DO IT!
Old Jul 27, 2015 | 11:41 AM
camucho's Avatar
camucho
I called Seattle Mini and unfortunately the repair kit is not available for the countryman, the only option is to buy the entire caliper housing. I will need to go after market if there is a kit available.
Old Jul 27, 2015 | 11:56 AM
cerenkov's Avatar
cerenkov
You can easily remove the piston to replace the boot. I have a dust boot that I can sell you from my 2013 MCS rear caliper.
Not sure if it is the same caliper or not.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
squawSkiBum
Oct 2, 2015 09:21 AM
StealthR53
Aug 8, 2015 10:59 AM
