R56 Rusty rotor or something else.
Old Jul 26, 2015 | 01:05 PM
micromini234's Avatar
micromini234
Can someone confirm what these water mark looking spots are(not the rust). These are new rotors and just want to make sure they're not high spots.
They have been on the car for about 150 miles, so they're not entirely bedded. The other side of the car doesn't have this on the rotors, so I'm a bit concerned. Sent from iPhone
Old Jul 26, 2015 | 03:30 PM
Drivehard's Avatar
Drivehard
Originally Posted by micromini234
Can someone confirm what these water mark looking spots are(not the rust). These are new rotors and just want to make sure they're not high spots. They have been on the car for about 150 miles, so they're not entirely bedded. The other side of the car doesn't have this on the rotors, so I'm a bit concerned. Sent from iPhone
Is this the side of the car that faces your sprinklers ?
If so may be hard water or simple corrosion
Sent from my iPad using NAMotoring
Old Jul 26, 2015 | 03:36 PM
micromini234
I don't have any sprinklers that would hit my car; where I park it.
Sent from iPhone
Old Jul 26, 2015 | 05:39 PM
SC R60's Avatar
SC R60
looks like what rust marks look like after you rub off the loose orange crud. Your pads should scrub the dark marks off if they are contacting the rotor properly. Try hitting the spots with scotchbrite.
If your new brakes are not bedded by 150 miles, I am curious as to what your break in procedure is
Old Jul 26, 2015 | 06:00 PM
Capt_bj's Avatar
Capt_bj
I would not worry about it
I see NOTHING unusual here . .
Old Jul 27, 2015 | 05:23 AM
richardsperry's Avatar
richardsperry
Except for the rust on the hats. But that's what you get with uncoated rotors...
Old Jul 27, 2015 | 01:34 PM
Yea, looks like someone sprayed water on them briefly after you parked the car. Surface rust. Yea and there not coated so the hat and edge are rusty.
Old Jul 27, 2015 | 01:39 PM
micromini234
Thanks for the replies guys.
When I'm able to get back on the road. I'll take it for a real drive on the highway and see if i can't get the rotors to clean themselves. Sent from iPhone
Old Jul 27, 2015 | 04:35 PM
minivinnie92's Avatar
minivinnie92
Ya 150 miles and there not bedded? Hmmmm
Old Jul 27, 2015 | 04:50 PM
micromini234
They don't appear to bedded, they're ebc reds. 150 miles is what it said on my odometer and I have no idea when I hit the reset, so it is very possible I haven't put that many on it.
Sent from iPhone
Old Jul 27, 2015 | 05:05 PM
minivinnie92
My bedding process is 5 stops from 40 to 10 mph pretty quickly do not stop the car u do not want to create a hot spot that 5 stops from 35 to 5 than a quick highway run to cool them off and your good you'll Snell all the crap burning off
Old Jul 27, 2015 | 05:16 PM
Capt_bj's Avatar
Capt_bj
did you do this on the car when you got it from the dealer?
Old Jul 27, 2015 | 06:09 PM
minivinnie92
Bought mine CPO so no but I am a technician and do it on all my brake jobs helps to elimanate any rotor noise before the customer drives it too
Old Jul 27, 2015 | 11:36 PM
renchjeep's Avatar
renchjeep
minivinnie92---sounds like a good bedding procedure to me. I work on Police vehicles for a career, and I do something very similar. But, I do it twice, first after install, then another after a complete cool down. And to the OP, I say more driving is in order. I see no issues so far.
Old Jul 28, 2015 | 04:25 AM
minivinnie92
Ya unfortunately a lot of times the customer is waiting and I don't get that luxury of a cool down the most important part is to not stop the car when they are that hot to u don't create a low spot
Old Jul 29, 2015 | 11:53 PM
renchjeep's Avatar
renchjeep
Another thing that has happened to me personally when stopping with hot brakes and holding the pedal on? Pad transfer. Makes for a rough spot on the rotor, which will lead to a pulsation in the brakes. Hard to bed brakes properly, but it must be done.
Old Jul 30, 2015 | 04:53 AM
minivinnie92
Ya well that's the thingwhen they are that hot they will imprint on the rotor so if I have to stop I try to use neutral and roll to a stop
FatherG
Oct 3, 2015 05:06 PM
Tires, Wheels & Brakes
Oct 1, 2015 02:22 PM
Oct 1, 2015 12:18 PM
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
