FS:: DDM Works R56 PFB
Old Jul 14, 2015 | 09:27 PM
mailmeamemo's Avatar
mailmeamemo
DDM Works R56 PFB
Price: $300
Location (Region): SoCal
Item Condition: Brand New
Brand New, never used, DDM Works MINI Pressurized Filter Box
Put your hood scoop to work for you.
$300 plus PayPal fee and shipping
MINI COOPER S R56 RACE INTAKE SYSTEM (RIS)BY DDMWORKS
The DDMWorks RAS (Ram Air Scoop) The unique shape of the DDMWorks RAS was designed to accelerate the incoming air from the hood scoop and keep the new intake box under pressure forcing even more cold air into the turbo and engine. Two diverters on the back of the RAS direct the air down into the filter, and the RAS seals with the top of our pressurized filter box (PFB) to ensure a cool ambient air supply. We also wanted regular maintenance of the car to be unaffected with the intake installed, so even with the RAS mounted to the bonnet of the car, regular maintenance of your engine is just as easy as stock. Access to the spark plugs, oil filter and oil fill are just like stock. The scoop attaches to the bonnet using existing mounting points so there is no drilling or modifications needed for installation. The RAS can also be purchased separately for use with other intake systems that leave an exposed filter in the back of the engine bay. We learned during our thousands of miles of testing that exposed filters without the RAS in place see good temperatures during light cruise, but during long pulls the temperature of the incoming air continued to climb as the turbo heated the air coming in through the scoop. With the simple addition of the RAS on those intakes, temperatures stayed only a few degrees above ambient, which resulted in better throttle response and more consistent power. The RAS is offered in black matte powder coat for a stock appearance.
The system comes in two parts, the RAS or Ram Air Scoop which makes use of the non functional hood scoop that was just waiting to be used as an intake source, and the DDMWorks PFB or Pressurized Filter Box. With the complete race system in place, your MINI's filter is washed with cool pressurized ambient air coming in from the front of the car. The whole system working together insures improved throttle response and maximum power consistently for your MINI.
Attached Thumbnails DDM Works R56 PFB-screen-shot-2015-07-14-at-9.14.50-pm.png   DDM Works R56 PFB-screen-shot-2015-07-14-at-9.13.38-pm.png   DDM Works R56 PFB-screen-shot-2015-07-14-at-9.13.13-pm.png   DDM Works R56 PFB-screen-shot-2015-07-14-at-9.15.00-pm.png
Old Jul 17, 2015 | 11:40 AM
meental's Avatar
meental
where are you located in socal? is this the V2 that will also fit n18 or early version that only fits n14?
Old Jul 17, 2015 | 12:07 PM
Baconism's Avatar
Baconism
Is this both the CAI and the under hood piece?
Old Jul 17, 2015 | 10:18 PM
mailmeamemo
located in LA, it's the V2, its a whole set, top and bottom, bran new
Old Jul 18, 2015 | 03:55 PM
minie's Avatar
minie
will this work with the mini gp strut tower bar?
Old Jul 18, 2015 | 07:00 PM
mailmeamemo
Gp 2
I am not certain it will fit the GP2 with the strut bar. I can call manufacture to find out.
Old Jul 20, 2015 | 11:57 AM
minie's Avatar
minie
sound good, keep me updated, cheers.
Old Jul 20, 2015 | 01:09 PM
mailmeamemo
The problem with the race intake system is that the MINIS with strut bars the
Mini-Ram-Air-Scoop will not clear. If you just use strut reinforcement plates, it will work fine.
Old Aug 7, 2015 | 05:51 AM
mailmeamemo
Tttt
Old Aug 7, 2015 | 10:15 AM
CptSlow's Avatar
CptSlow
for quick reference the two parts in question:
hood addon:
http://www.ddmworks.com/Mini-Ram-Air...rks_p_261.html
airbox replacement:
http://www.ddmworks.com/R56-PFB-Pres...rks_p_155.html
oddly enough they dont discount when buying both parts together:
http://www.ddmworks.com/Mini-Cooper-...rks_p_156.html
Old Aug 8, 2015 | 06:54 AM
Mikli's Avatar
Mikli
Sold to me! Thanks M. Can't wait to install it.
Mikli
R55 :: Clubman Talk (2008+)
Jun 26, 2019 05:58 AM
tr3y003
Oct 22, 2015 10:48 AM
thebordella
Aug 31, 2015 01:37 PM
