R56 Mini cooper S 2009 check engine p0012 p0300, p0301, p0302, p0304 codes
Old Jul 8, 2015 | 11:20 AM
eliseo1981's Avatar
eliseo1981
Hello everyone, new here. Just bought a used mini and had the clutch changed, the mechanic told me the oil was low (or almost non existent) and added oil as well.
I got home and decided to clean the air filter (with a compressor) and take out the spark plugs and clean those as well, I was unable to take the spark plugs out as I didn't have the correct socket so I put everything back together and now the check engine light comes on, the car stutters some and also turned off once already by itself.
I took all the spark plug solonoids out and cleaned them, pushed them all back in tight and also took the air filter out again and cleaned that as well again and put it all back together. I then read the vvt solonoid could be an issue so I took that out and cleaned it with a rag as it was full of oil. I put it back in and the car doesn't seem to stutter anymore but the engine light is on.
In addition, the engine oil seems to be overfilled by probably up to one quart and it didn't help I added an oil additive for cars with over 50k miles (I have 81k).
Sorry for all this crap I did and I know it could be multiple issues, but I do notice that removing the oil cap or dip stick has a lot of negative pressure and the car stutters when I do that.
Can anyone help or guide me to the right direction?
Old Jul 8, 2015 | 02:20 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
NAM thread on codes P0300 and P0304
NAM thread on Code P0012 (Specifically post #7 since oil is overfilled)
NAM thread on Code P0301
NAM thread on P0302 and another here.
See if any of these help resolve your issues. Good luck!
888.280.7799 | 6am - 5pm PST
Old Jul 8, 2015 | 03:37 PM
pokeyjoe's Avatar
pokeyjoe
Veteran: Navy
Looks like the previous post should help diagnose your codes. BTW, don't use compressed air to clean your air filter. It enlarges the holes and ruins the filtering capability.
Old Jul 8, 2015 | 05:46 PM
AZdsrt's Avatar
AZdsrt
The p0012 could be a VANOs solenoid, which could cause misfire..
Old Jul 8, 2015 | 06:17 PM
eliseo1981's Avatar
eliseo1981
Thanks for the info on the air filter will stop doing that didn't know that would damage the filter.
Thanks guys for all the other info, ended up taking apart all the plug cables again and pushing them down firmly. The car then started to act normal and then took it to the mechanic here where he reset the CEL as he said once it is triggered it stays on (is this even true)?
Anyways seems to be ok now.
Old Jul 8, 2015 | 06:53 PM
67morris's Avatar
67morris
yes, the cel will stay until cleared even if the problem is fixed.
Old Jul 9, 2015 | 02:16 AM
Systemlord's Avatar
Systemlord
So you bought a Mini with almost no oil? You messed with a lot of things (Vanos solenoid and coils) , you might try driving the Mini some distance (30 miles) to see if the codes clears. I had my Mini in for a check-up and my boost tube popped off on the freeway, clamped it and drive to the beach, code cleared itself.
Was the screen dirty on the Vanos solenoid, VVT as you called it same thing?
Pelican to the rescue.
Old Jul 9, 2015 | 08:38 AM
PelicanParts.com
Vendor
whoo-hoo!
Can read up on some information about the VANOS Solenoid here too if interested. Hopefully your issue is resolved. Let us know what happens and if anything changes!
Old Jul 19, 2015 | 09:22 AM
eliseo1981's Avatar
eliseo1981
Yea the screen on the Vanos Solenoid was very dirty, I ghetto cleaned it with just a rag. The pelican part site is freaking awesome. I am afraid to clean it with the brake cleaner are you guys sure it won't screw up something?
Old Jul 19, 2015 | 12:08 PM
Systemlord's Avatar
Systemlord
Brake cleaner, why not use compressed air can? Do your engine a favor, next oil change pour BG EPR into oil crankcase and follow instructions. It will liquefy all built up carbon everywhere oil travels, every time you turn off the engine oil bakes itself to engine parts. I had 55K miles when I used the BG EPR and you haven't seen black oil until you see what comes out after BG EPR!
I wish I had taken DSLR pictures of my oil draining out, it had black swirl marks in the oil as it drained. I hade to use up an extra 5 quart jug of good oil just to do a second flush, it was that bad. Here's what my Vanos Solenoid looked like when I removed it for the first time. Link
Old Jul 20, 2015 | 03:56 PM
PelicanParts.com
Vendor
It is fine to use. Use non-chlorinated (not sure if chlorinated is still available) and dry it out before reinstalling. That is about it. If you are uncomfortable, which is understandable, use dish soap and water and allow to dry.
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Lt. Dan
Aug 10, 2015 08:23 AM
nomar116
Aug 9, 2015 09:42 AM
Aug 7, 2015 05:56 AM
