JCW Compact Spare for F56 JCW.....anyone found one yet?
Old Jul 2, 2015 | 12:57 PM
NHcountryman's Avatar
NHcountryman
Hi
2015 F56 JCW with 17" black Track wheels , dynamic dampners.
1.Not a fan of run flat tires....
2. Travel to areas with NO cell coverage so AAA and Mini Roadside service not always a option....
3. Looking for a compact Spare or full size spare that can be user on front or rear to carry on long trips like MTTS2016 (crosscountry)
4. Already carry Mini tire kit ( Air pump and Filler) and a tire repair kit.....
any options for spare wheel and tire ( prefer not buying a Mini Rim - $$$$)
Old Jul 2, 2015 | 03:05 PM
hammerhands's Avatar
hammerhands
Those steel rims are pretty cheap. But you can get the MINI spare that comes with the 3-cylinder, and there's a cover someone makes for it.
Scratch that, the compact spare wont work with the big brakes. Oh, I'm not sure. It says the wheel can go on the rear, and the good wheel on the front. Maybe ECS can clarify. It says on RealOEM that it wont work with the JCW retrofit brake kit, but maybe that is only the front?
I guess not for the JCW [or which brakes do you have?] from Detroit Tuned website:
"will fit over most front brakes that the MINI has, but will fit over ALL REAR brakes on the MINI UNLESS you have the Sport Brakes, M MSort Brakes or JCW Sport Brake option (brembo kit)"
Well, Detroit Tuned has an adapter for the 4-bolt wheels so the big brakes can be used with the spare, I wonder if they would make them for the 5-bolt?
The emergency rim, but where is the tire?
http://www.ecstuning.com/ES2781985/
15" steel rim, has the same warning as the Emergency rim about JCW brakes.
http://www.ecstuning.com/News/MINI_F...015/ES2798744/
Spare wheel alternative
http://www.outmotoring.com/micro-spa...l-f56-5-4.html
Or
http://www.detroittuned.com/mini-coo...re-tire-5-lug/
Custom Bag
http://www.detroittuned.com/detroit-...pare-tire-bag/
Old Jul 11, 2015 | 08:37 AM
Sneakz's Avatar
Sneakz
Does anyone know if the 15" steel rims that ECS tuning has would fit over stock front F56 brakes?
Old Jul 11, 2015 | 01:42 PM
GregoryK's Avatar
GregoryK
I believe they will fit over the back brakes only. if you get a flat in the front.....I'm sure you can figure it out.:-)
Old Jul 11, 2015 | 01:49 PM
Sneakz's Avatar
Sneakz
Really? I know they'll fit on the F56 Cooper front brakes as Justas can be had with 15" wheels. But was hoping they'd fit on a F56 Cooper S cause I have an existing set of 175/65R15 winter tires that are fairly new.
Old Jul 13, 2015 | 01:06 PM
The believe the steel wheel will fit front on the " Cooper " and rear , but will only fit the rear on the Cooper S . So if you get a flat on a Cooper S on the front, you will have to swap the wheel from the rear and then set the spare steelie on the rear.
Old Oct 30, 2015 | 08:18 AM
OutMotoring's Avatar
OutMotoring
Vendor - 15 Years
Old Nov 4, 2015 | 07:57 PM
Sailorlite's Avatar
Sailorlite
Will it fit on the floor of the trunk? What is the outside diameter of the tire? Thanks.
Old Nov 5, 2015 | 06:10 AM
OutMotoring
Vendor - 15 Years
It is about 22" across so it will not sit flat in the trunk but can sit at a angle if leaned against the back of the back seats.
Old Apr 6, 2018 | 09:07 AM
oxtox's Avatar
oxtox
so has anyone tried one of these on an F56 JCW yet?? (I have a call out to aaron @ outmotoring)
Old Apr 6, 2018 | 10:00 AM
TVPostSound's Avatar
TVPostSound
Like any F56, if the flat occurs on the front tire, you move the rear to the front, and install the spare to the rear.
EXCEPT FOR BIG BRAKE KIT WONT WORK.
Old Apr 6, 2018 | 10:59 AM
ASKtheteach's Avatar
ASKtheteach
On a JCW (or any MINI with the big brake kit), you cannot use a compact spare on the front, as it will not clear the brakes. You would need to jack up one side of the car, put the rear wheel on the front, and then put the spare on the rear. Yes, it’s extra work, but that’s how it works.
Old Apr 6, 2018 | 01:27 PM
oxtox's Avatar
oxtox
That makes too much sense! Extra work, but so much better than waiting for roadside assistance! Thank you both!
Old Apr 6, 2018 | 02:37 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
Yep, with any of the JCW Brake cars you need a spacer to make it even fit on the back!
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
kazyn
Oct 25, 2019 02:34 PM
TJANK
Aug 24, 2015 06:11 PM
blackie
Aug 23, 2015 08:44 PM
Mrdi
Aug 7, 2015 01:06 PM
