throwing p3030 code
Old Jun 29, 2015 | 03:32 PM
tonsabe's Avatar
tonsabe
throwing p3030 code
And also I get put into Limp mode. this is occurring with more frequency,, about 4 time in the last week. Happens with a miss fire when hard acceleration.my mini is 2011 S model. Question is this? I the misfire likly to be from a plug or coil problem or a more serious issue like carbon or maybe hpfp. I can mannage the coils or/and plug issue, but beyond that i guess it wll be a trip to the dealer (about 150 miles). thanks for your thoughts
Last edited by tonsabe; Jun 29, 2015 at 03:35 PM. Reason: plus this: 75,000 mile,orig. plugs my guess
Old Jun 29, 2015 | 06:42 PM
AZdsrt's Avatar
AZdsrt
Mis-fire code quite often means either spark plug or coil. How many miles? Pull out the plugs and see if they are still good. You can always swap the coils and see if the code changes..
Old Jun 30, 2015 | 12:09 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Yes, it's a misfire code. Good suggestion to switch the coils around and see if it follows the coil. When's the last time you did routine maintenance on the car? We have a good maintenance kit here that may be useful if it's time for these items to be done. Otherwise, if it's a bad coil you can pick up some here. Let us know what you find!
-Luccia
888.280.7799 | 6am - 5pm PST
Old Jun 30, 2015 | 03:46 PM
tonsabe's Avatar
tonsabe
Swapped out the plugs. #3 had a bit more carbon buildup at the tip than the others. Strange part was an ultra fine thread of carbon that was bridged across the gap? New plups also studered a few times until the engine reached temp +200. Everything felt great after I got the temp up!
Old Jun 30, 2015 | 03:51 PM
PelicanParts.com
Vendor
Hm, makes me think, when was the last time you did a carbon clean up? Read more about it and how to here.
-Luccia
Old Jun 30, 2015 | 03:59 PM
tonsabe's Avatar
tonsabe
Did the Sea-foam (3way,fuel, case and turbo)
right after I got the car in May
Old Jun 30, 2015 | 09:20 PM
hamptup's Avatar
hamptup
How many miles on the car and do you have any mods?
Old Jul 1, 2015 | 08:49 AM
PelicanParts.com
Vendor
Is it acting up every time now when you start it until it gets to operating temps?
-Luccia
Old Jul 1, 2015 | 08:56 AM
tonsabe's Avatar
tonsabe
yes, now with new plugs, i am experiencing a sputter as i apply medium/heavy throttle from slow speed? less evident after warm up, but still present
Old Jul 2, 2015 | 09:36 AM
Slave to Felines's Avatar
Slave to Felines
That's not carbon cleaning. That's a placebo. (OK, not quite completely, but it's no substitute for real carbon cleaning.)
Real carbon cleaning requires pretty hard scrubbing. The walnut shells do a very good job of that, or you can get in there with picks and various instruments and scrape as much crap out as you can by hand.
If you want to verify whether or not you need the cleaning, borrow or buy a borescope. There are some pretty inexpensive ones on Amazon, among other places. Pull the intake apart and then slide it into the manifold until you get to the valves. If you're completely grossed out by what you see, you need walnut blasting.
Old Jul 2, 2015 | 09:39 AM
PelicanParts.com
Vendor
+1
-Luccia
Old Jul 2, 2015 | 09:23 PM
Systemlord's Avatar
Systemlord
There's no way Seafoam can remove the heavy hard carbon on your intake valves, it requires some serious effert to remove this rock hard carbon. Walnut media would be second only to sand blasting if you could imagine.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
xpunisherx
Nov 27, 2015 03:32 PM
embiggenedmini
Oct 15, 2015 12:36 PM
sirfrank
Sep 11, 2015 01:36 PM
NHcountryman
Sep 6, 2015 11:01 PM
