R56 CEL P0073 and P0579
Old Jun 25, 2015 | 10:09 PM
tll_2k's Avatar
tll_2k
CEL P0073 and P0579
I just replaced my thermostat housing, and after I got everything together and the air bled, I noticed the cel came on. I pulled the codes and they are P0073 and P0579. The car runs fine, but I'd like to fix the problem before it becomes a real problem. I assume I mixed up some wires somewhere. I noticed when I checked just now that the plugs seem to be color coded, but I have the green connector hooked up to the top of the thermostat, which is brown. Is that correct? I tried swapping the green connector with the brown one, but the green one wouldn't go into the turbo intake connector. I know this is going to be a stupid mistake, bu I could use some ideas. Thanks!
Old Jun 26, 2015 | 12:00 PM
AZdsrt's Avatar
AZdsrt
I don't have any solid suggestions, but did look up the codes -
P0073 Ambient Air Temperature Sensor Circuit High Input
P0579 Cruise Control Multi-Function Input "A" Circuit Range/Performance
They don't seem to be related, so wonder if you didn't connect something back correctly?
Old Jun 26, 2015 | 12:06 PM
Systemlord's Avatar
Systemlord
Were these codes the reason you decided to replace the thermostat housing? Ill have a look at my Bentley manual.
Why is it every time I look for P codes in my Bentley manual I always come across different but similar numbers, ie. P0597 instead of P0579?
I show P0597 being "Program map thermostat, control activation: Open circuit." As for P0073 "Ambient Temperature Sensor Circuit High."
Where you getting your codes? The code P0579 isn't anywhere in my Bentley manual, you must be getting them somewhere else.
Old Jun 26, 2015 | 12:46 PM
tll_2k's Avatar
tll_2k
The "ambient air sensor" and "cruise control multi-function input" descriptions are what autozone printed out for me too. I figured they were probably wrong, but at least it narrowed it down to an electrical problem.
I had to replace the housing because I had a bad leak. The housing ended up being broken on the small tube that connects to the turbo line. Could someone please remove the plug on the intake near the turbo and tell me what color the plug is? Thanks!
Old Jun 27, 2015 | 09:16 AM
johne123's Avatar
johne123
The plug that goes to the sensor on the turbo air intake is brown. I'm surprised one could mix this up. I also recently replaced my thermostat housing and got confused on reassembly between that one and the one for the coolant temp sensor on the housing. Coolant sensor itself is brown so you'd expect a brown plug to go to it, but that doesn't fit. Looks like it should, but it doesn't. So green plug goes to brown coolant sensor. Brown plug goes to black turbo intake sensor. If that's the ambient air temp sensor, then swapping those two plugs (which is impossible without breaking something on my car) could cause "Ambient Temperature Sensor Circuit High."
Did you forget to connect the cable to the thermostat itself? Leaving that off would definitely cause "Program map thermostat, control activation: Open circuit."
Hope that helps.
Old Jun 27, 2015 | 12:01 PM
Systemlord's Avatar
Systemlord
I wonder why Mini engineers are colorblind, wouldn't make more sense to have matching colored plugs to make it simple? I just don't get it...
Old Jun 27, 2015 | 12:30 PM
tll_2k's Avatar
tll_2k
Thanks for that, johne123! I had them hooked up correctly, after all. I pulled the air intake and the lower plug on the thermostat housing was not plugged in all the way. I could pull it out without popping the tab. I hooked that back up, but everything else seems okay. Do you think that both errors might have been from that one wire somehow?
@Systemlord: I thought the same thing! I noticed the grey connector and that the grey wire went to it and that's when I panicked. I was looking all over for the green plug and another wire for the intake. lol
Old Jun 27, 2015 | 12:48 PM
Systemlord's Avatar
Systemlord
Great so everything is solved no more issue with the codes? If codes still remain best thing you could do is drive it and let the ECU correct itself.
Old Jun 27, 2015 | 05:47 PM
tll_2k's Avatar
tll_2k
I didn't have a chance to clear the codes today, but while driving around the CEL went off! All good! Strange that the one plug threw two different codes, but I'm glad it's all fixed. Thanks for your help, everyone!
Old Jun 28, 2015 | 01:18 AM
Systemlord's Avatar
Systemlord
Your welcome, glad to lend a hand and learn something at the same time.
To anyone who finds this thread it would be a great idea to take pictures of the connectors before you pull them.
neezebeeze
Oct 31, 2016 12:10 PM
rob&JCW
Oct 9, 2015 11:12 AM
potterstein
Oct 2, 2015 09:30 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
Nick Royer
Sep 16, 2015 08:17 AM
