R52 Small drips on inside of window after washing car?
Old Jun 9, 2015 | 01:36 PM
zr0z's Avatar
zr0z
Washed my 06 R52 for the first time after buying it 2 1/2 weeks ago yesterday. Everything turned out great, but I watched a few small drips form and drip down the inside of all of my side windows in the process. The wash was pretty thorough, so it may have been that?
It wasn't much water (maybe 3-4 drips down each window), but the seal around the window seemed to be wet and not 100% sealing. Is this normal? The seals seem to be in good condition.
Thanks!
Old Jun 9, 2015 | 01:41 PM
Swimbaxter's Avatar
Swimbaxter
There is at least on thread on here dedicated to this and other R52 problems. I had something similar and changed the whole seal (wasn't cheap) only to discover that didnt fix the problem. My problem turned out to be that the windows themselves needed to be adjusted because they did not move far enough upward to properly seal. The real cost to fix was labor and you tube. Moral of the story, start with the cheapest option first. Lesson learned on my part.
Old Jun 9, 2015 | 02:10 PM
Around the window seal can be adjusted by the window itself :
https://www.northamericanmotoring.co...ndow-leak.html
, they put spacers on the seal right above the rear window.
Also they front seal can be updated:
https://www.northamericanmotoring.co...eaking-in.html
Old Jun 9, 2015 | 05:48 PM
damncajun's Avatar
damncajun
Is this normal? No and not acceptable.
Old Jun 10, 2015 | 05:10 PM
BoDarville's Avatar
BoDarville
+1. A $5 bicycle gear tool and a few minutes of tinkering solved all of my problems. Tight as a drum now.
Old Jul 30, 2015 | 04:17 PM
blonda's Avatar
blonda
Good info. I noticed that my R52 (just purchased a month ago) was leaking on passenger side when I washed it. Will have to add to my "fix it" list
Old Jul 31, 2015 | 06:48 AM
Welcome.
WarEagle
R55 :: Clubman Talk (2008+)
May 3, 2019 03:00 AM
Dec 23, 2015 10:36 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
kwijmbo
Aug 5, 2015 09:00 PM
