R56 License Plate Bulb Malfunction!
I installed LED bulbs and have had no problem. Suddenly my mini is now insisting that my bulbs are malfunctioning when they're both still working perfectly. Is there a reset for this annoying code? Any help is appreciated!
The LEDs can be finicky. When I installed mine I would periodically get the bulb error but not always.
I did end up using NCS Expert to reprogram the FRM module computer so it would not perform the bulb check.
What bulb is causing the error? Are you sure it is the license plate bulbs?
Go Warriors?
Cause the LED ones look sweet at night time! Lol 😂
Which LED bulbs did you buy? If you don't program out the warning, you need to use so-called "Canbus" LED bulbs that have an integrated resistor to simulate the electrical load of a standard bulb.
LED lights draw far less current than standard filament bulbs. LEDs draw so little current that they can make the footwell module think the bulb is burned out. That's the reason for "canbus" LED bulbs.
Why do they have such large heat sinks on them?
They should be Canbus and have heatsink ? Like our Ziza ones.
Also check the contacts on the prongs , sometimes the rear lens pops off or get water under there and then the connection is intermediate.
https://www.northamericanmotoring.co...te-lights.html
https://www.northamericanmotoring.co...-car-wash.html
I replaced my license plate bulbs w/LED's.....they work fine and haven't thrown a code yet but I did notice when unlocking the car they blink like strobes until I lock it up again or the interior lights cut off.....
A "Canbus" LED simulates a standard bulb by using a resistor to draw as much power as a standard bulb. When drawing that power, the resistor will also get as hot as a standard bulb. The heat sink is to dissipate the heat, which would otherwise burn out the LED.
"Canbus" LEDs effectively defeat two advantages of LED technology: low power and low temperature. They are a hack workaround and the proper solution is to reprogram the car so that it recognizes LED's instead of expecting standard bulbs to be in the circuit.
hamptup
R55 :: Clubman Talk (2008+)
18
Nov 29, 2016 05:04 PM
Sep 11, 2015 01:15 PM
