half yellow engine light without error codes
Old Jun 7, 2015 | 12:33 PM
genik's Avatar
genik
When i step on the throttle, around 4000rpm, i get overboost which is fine. After that though, when i lift my foot from the pedal as the car slows down, i get a half engine yellow light. The car i believe gets in limp mode and i cannot get overboost, generally it seems as if the car has lost its power.
If i pull over, shut down the engine and start up again, the yellow engine light disappears and driving power is back again, but only just for once because if i push it, the same story happens (yellow half engine, lack of power, no overboost etc.) until i shut down engine again etc.
There is no error code diagnosed when using Torque from my smartphone, isnt this strange?
Old Jun 7, 2015 | 12:52 PM
cccplus's Avatar
cccplus
unfortunately, torque can not read all bmw/mini codes.
Old Jun 7, 2015 | 06:45 PM
AZdsrt's Avatar
AZdsrt
^ this. You need to either take it to a Mini independent or the dealer to get the codes. Not much troubleshooting can be done without them..
Old Jun 7, 2015 | 08:38 PM
redparchel's Avatar
redparchel
if you'd rather not take it to the dealer just yet, I ran into a similar situation recently and found as you did torque does not read the BMW/MINI codes outside of the standard OBD-II stuff, but if you want to spend a bit more money the 'carly for BMW' (previously known as BMWhat) app and adapter will read those other codes. I've been using it for a few months. (there's a few threads about it on here like here and here)
there's also bavTech i opted not to go with it as there wasn't too much information about it's capabilities on the r56, it required a laptop, an was about 3times as much as 'carly'.
good luck, hope you find the solution quickly!
Old Jun 8, 2015 | 12:38 AM
Systemlord's Avatar
Systemlord
Whatever is going on seems to be when your PCV system is under a lot of pressure, that's when the N14 start drinking oil. Positive pressure on WOT and negative pressure on deceleration.
Old Jun 8, 2015 | 12:33 PM
genik's Avatar
genik
Thanx for the contribution , but what exactly do you think that could be the issue?
Old Jun 13, 2015 | 11:15 PM
Systemlord's Avatar
Systemlord
It could be your diverter valve mounted to the turbo housing, if it's leaking you losing boost pressure hence loss of power. Every time you decelerate the DV is suppose to open.
Old Jun 15, 2015 | 07:48 AM
afadeev's Avatar
afadeev
Not really - Troque app only reads generic OBD2 errors, and is oblivious to custom MINI/BMW error codes.
Error codes are 100% there, you are just using the wrong tool to read them. You have two choices:
1). Take the car to a MINI mechanic - independents will usually read the codes for free, dealer will likely charge you for 1+ hours of "labor".
2). Buy a proper ODB2 code reader. Cobb AccessPorts (used only at this point) or one of many others.
Please don't throw parts at the guesses as to what the problem might be, as it will be get very expensive and very frustrating first. Read the codes, then tackle the problem!
a
Old Jun 15, 2015 | 12:03 PM
genik's Avatar
genik
Can you please be more specific to what model you suggest for scanning from the OBD2 port?
Old Jun 15, 2015 | 12:32 PM
Systemlord's Avatar
Systemlord
You'll probably pay more for the scanning tool than getting your Mini diagnosed.
Old Jun 16, 2015 | 06:56 AM
afadeev's Avatar
afadeev
Something like the following (search the Marketplace on this forum):
https://www.northamericanmotoring.co...ccessport.html
There has to be something out there that's cheaper, but this one both scans/resets the codes, as well as upgrades the DME programming.
YMMV,
a
mini yellow-haa!
Aug 13, 2015 11:18 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
