R56 Torque Test Log
Old May 20, 2015 | 09:31 AM
laforze's Avatar
laforze
Torque Test Log
So i've hooked up my Kiwi BT adapter again and was playing around with the torque app. I found this test log and don't know what i'm looking at tbh.
Can anyone give me any insight to what is shown below. Specifically to what has failed (2 tests).
Thanks in advance for any feedback.
Vehicle Calibration ID: 000007601756
000007623107
ªªªªªª
Test report:
MID:$01 TID:$83
- O2 Bank 1 Sensor 1
Max: 1.99882 Min: 0.29963
Test result value: 1.10678
PASS
MID:$02 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
Max: 0.74359V Min: 0.74359V
Test result value: 0.74359V
PASS
MID:$02 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 2
PASS
MID:$02 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 2
Max: 300ms Min: 0ms
Test result value: 10ms
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 1.15461V Min: 0V
Test result value: 1.02468V
PASS
MID:$02 TID:$81
Max: 0.74274V Min: 0V
Test result value: 0.73298V
PASS
MID:$02 TID:$82
Max: 1.15754V Min: 0.74274V
Test result value: 0.7525V
PASS
MID:$02 TID:$86
Max: 5,000ms Min: 0ms
Test result value: 540ms
PASS
MID:$21 TID:$81
- Catalyst Monitor Bank 1
Max: 65,535 Min: 5,121
Test result value: 5,360
PASS
MID:$3b TID:$81
- EVAP Monitor (0.090")
Max: 65,535 Min: 2,874
Test result value: 2,875
PASS
MID:$3c TID:$81
- EVAP Monitor (0.040")
Max: 65,535 Min: 3,999
Test result value: 3,999
PASS
MID:$3d TID:$86
- EVAP Monitor (0.020")
Max: 9.99393 Min: 0.04971
Test result value: 0.05063
PASS
MID:$3d TID:$87
Test incomplete or dependant test failed
MID:$41 TID:$85
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 1,239.90002°C Min: 789.90002°C
Test result value: 820°C
PASS
MID:$42 TID:$81
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 756Ohm Min: 0Ohm
Test result value: 118Ohm
PASS
MID:$81 TID:$7c
- Fuel System Monitor Bank 1
Max: 3.3 Min: 1,033.70007
Test result value: 2,073.6001
FAIL
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 2Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
Test result value: 1Count
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
Test result value: 0Count
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$f1 TID:$7c
Manufacturer defined MID -
Max: 0 Min: 8,273
Test result value: 31,984
FAIL
USA-RET
Nov 9, 2015 07:27 PM
hydouken
Sep 15, 2015 05:49 AM
papawhiskey
Sep 14, 2015 05:47 PM
