JCW Turbo is dead
Turbo is dead
I've got a '09 jcw that apparently need a new turbo. I figured I'd upgrade it from an oem while I'm at it. Any suggestions on a higher performing turbo? I've done some minor upgrades (intake, intercooler). Any advice would be greatly appreciated.
Factory turbo JCW 11657583149 here is you don't go down the performance road.
http://www.ecstuning.com/Search/SiteSearch/11657583149/
Larger Intercooler and resonated pipe delete are good upgrade, also the sound tube / pipe delete on the back side before the intake manifold.
If you want to upgrade and have the cash to do so, then do it. Make sure you do the proper supporting mods with the upgrades. I run a GTX by Turbo By Garrett (non Mini car), but my car also has a built motor. Borgewarner is a good turbo company as well. Blouch turbo is another. Do your research. Otherwise, OEM is here.
-Luccia
-Luccia
888.280.7799 | 6am - 5pm PST
Whats
a pipe delete?
factory turbo jcw 11657583149 here is you don't go down the performance road.
http://www.ecstuning.com/search/sitesearch/11657583149/
larger intercooler and resonated pipe delete are good upgrade, also the sound tube / pipe delete on the back side before the intake manifold.
Not sure what your goal is but if you go bigger you will prob need to have a tune put on the car as well. Plus other things like a catless DP etc.
The JCW will run OK with the stock tune and a bigger turbo. If I recall correctly the stock JCW turbo has a 38mm cold side opening and the replacement I used was a JMTC 42mm. Really didn't have any problems, but decided to have Jan from RMW clean up the tune and do some tweaking. Much happier after that.
Pker
Apr 11, 2017 12:14 AM
jennster
Sep 28, 2015 06:19 PM
EVMini
Sep 28, 2015 10:20 AM
