R56 Yellow Engine light on hard Accel
Old May 8, 2015 | 08:01 AM
Bosgarage57's Avatar
Bosgarage57
Hey mates,
07 MCS, 54K miles. Ive been noticing on hard accelerations, well not really hard, but if I keep the RPM's at about 3k and give it gas I get the yellow half engine light pop up. I plug my scan gauge in and it doesn't read an error code, I cant make it reset either unless I clear trouble code on my scan gauge.
Any suggestions? I don't know if it needs a walnut blast or if its something I can do at home. My power isn't decreased when it comes on either. Its just annoying.
Old May 8, 2015 | 08:15 AM
scf's Avatar
scf
Check plugs, and their gap. Ended up in limp mode yesterday due to plugs, and 1 bad coil.
Old May 8, 2015 | 08:55 AM
Bosgarage57
Ouch, were you experiencing any problems or was it out of the blue?
Old May 8, 2015 | 10:56 AM
scf's Avatar
scf
Out of the blue. On ramp to the highway, got into it. Not floored, but more than half way pedal down. When the turbo spooled up everything went flat. Blaaaaaaaahhhhhhhhhh....then the limp mode light came on in front of me, and the CEL lit on the speedo in the dash.
Not saying this is your problem. But it's an easy and free check before you go further. Depending on your scan gauge, it may or may not display the code, not all of them do all of the codes.
Old May 8, 2015 | 05:07 PM
HogWldFLTR's Avatar
HogWldFLTR
My CPO program mini had the yellow engine light come on today after a hard acceleration and it's stayed on. Going in Monday to have them take a look. 57K miles. They said as long as it drives OK it is OK to use. We'll see.
Old May 8, 2015 | 05:14 PM
jared_g91's Avatar
jared_g91
Whoa! Exact same thing happened to me a couple of weeks ago. Accelerating on the highway at 5th gear when it felt weird. Then put it in 6th and tried to accelerate more when it went into limp mode. Went to autozone so they can use their generic reader but no codes. Was going to wait until the weekend to get it checked at MINI, but under the same scenario getting on the highway the light came off after a semi hard acceleration. Let me know what it is! BTW turbo was spoiling fine from what I could hear. Have an 07 MCS w/ 104,000 miles.
Old May 8, 2015 | 05:30 PM
a2oc's Avatar
a2oc
superknock?
Old May 18, 2015 | 07:42 PM
shakeypuddin's Avatar
shakeypuddin
Mine too. 2007 R56 w/89k. Multiple misfires confirmed. P0303 and P0304 swapped plugs to no avail. Going in tomorrow to a local Mini service place... avoiding the dealer at all costs.
Old May 19, 2015 | 07:50 AM
Bosgarage57
Keep us informed please! I have no misfire codes tho when I check.
Old May 19, 2015 | 05:59 PM
Sploit1121's Avatar
Sploit1121
I also have a CPO, had the same problem being described here, and took it into the dealer. I was under the impression that they would be able to diagnose the problem under the warranty. This is not the case. They wanted to charge me 300 dollars to change spark plugs (seriously?) and would not cover the diagnostic under the warranty. Charged me 150 for doing nothing all said and done. Will never take it in again.
Old Jul 19, 2015 | 10:24 AM
bigbacon's Avatar
bigbacon
shakeypuddin:
what ended up being the issue?
Old Jul 23, 2015 | 01:08 PM
VII's Avatar
VII
Bump. Recently bought an '07 with 109k miles and accelerating onto the freeway gave me the brief engine light with stumble but went away as quickly as it came. No codes my scanner could pick up. I'm curious to see what others find.
Old Jul 23, 2015 | 05:52 PM
AZdsrt's Avatar
AZdsrt
Without posting the code, is a shot in the dark. You got a CEL, you got a code. Need to either take it to a mini dealer/specialist, or purchase a code reader capable of pulling BMW/Mini specific codes..
Etrain
16
Aug 5, 2024 04:37 AM
mini yellow-haa!
Aug 13, 2015 11:18 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
