R50/53 Question
Old May 2, 2015 | 08:51 AM
rossgo_R53's Avatar
rossgo_R53
Question
Have my 2003 r53. And it seems almost every cruise I go not matter if it's 2miles to mc Donald's or 10miles to my house. The fan always turns on after turning the car completely off. I was wondering if it's happening because I need a oil change? Check my radiator ? I don't no just wondering if it's normal or what I should do
Old May 2, 2015 | 09:18 AM
Fly'n Brick's Avatar
Fly'n Brick
You may be growing a problem with the power steering pump. This issue is heavily covered in previous posts. For example: https://www.northamericanmotoring.co...hut-off-2.html
Old May 2, 2015 | 10:23 PM
ZippyNH's Avatar
ZippyNH
Check your coolant?
Mini's often have leaky coolant tanks, and thermostat gaskets....net result...low coolant, so the car runs hot...so the fan turns on and runs even after shutdown...normally the cooling fan should not only run after shutdown if the car has been driven VERY HARD...
Both items are easy to fix...under $100 if you diy it....
Old May 2, 2015 | 11:34 PM
rkw's Avatar
rkw
In addition to what Brick and Zippy mentioned (both are common problems and possible causes), one more possibility is that your low speed fan is never turning on because the low speed fan resistor is burned out (this is yet another common problem). The engine is running hotter than it should, and after you stop the retained heat is enough to trigger the high speed fan.
https://www.northamericanmotoring.co...-solution.html
Old May 4, 2015 | 03:02 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I would start by checking your coolant level and look for leaks.
-Luccia
888.280.7799 | 6am - 5pm PST
Old May 4, 2015 | 04:27 PM
Fly'n Brick
Zip, I knew you couldn't stay away. Good to see you still sharing your wisdom.
Old May 4, 2015 | 05:12 PM
ZippyNH's Avatar
ZippyNH
Yeah...figure I'll drop in sometimes...
Still love the gen1 mini's!!
Old May 7, 2015 | 10:29 AM
Rayanmx's Avatar
Rayanmx
For me it was all three factors that ran like a chain reaction in the following order:
1. Fan resistor failure thus engine was working hotter than usual
2. Premature thermostat housing damage (maybe due to engine running hotter?) causing leaks
3. Water reservoir leaking due to boilovers
How I fixed it:
1. Replaced entire fan ($75 on Amazon)
2. Replaced thermostat and its housing ($45 on O'Riley)
3. Replaced water reservoir ($20 on yard)
Engine running cooler now (in the range of 88C to 110C). Still waiting to see how it behaves in the coming summer heat. (fingers crossed)
Cheers!
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
twriter
Oct 2, 2015 03:14 PM
Carwash
Sep 15, 2015 02:02 AM
marc0011
Sep 10, 2015 10:04 PM
