R56 DoS Intake Sliding Off... Need a clamp
Old Apr 14, 2015 | 11:24 AM
Grizld700's Avatar
Grizld700
Ok, as the title says, my intake tube is sliding off.
I have the hard JCW intake tube on my '07 S. I've done the turbo inlet flange, intake seals, and intake tube cleaning with brake clean. But with the DoS intake, the thing is slipping off.
I've searched the forums and it appears at one point Clint with DoS was selling T-Bolt clamps for those who needed them. The specs are listed on post #119 HERE.
Here is an easier look at the important part of the post:
Originally Posted by Mini'mon
The clamps are about 2.22" (56.5mm) in diameter. The band is a little under 3/8" wide (about 9mm width).
Ok also further in the thread mentions the use of McMaster-Carr for the use of other bands that a NAM member needed. But for this application it appears as though McMaster-Carr does not carry the T-Bolt clamp needed.
Does anyone know where I might be able to get a clamp like this? I've searched online and at my local hardware store. It appears the thin band makes this a rare clamp. The band needs to be that thin to stay with in the intake tube groves.
Any help is always appreciated.
Old Apr 15, 2015 | 08:33 AM
Grizld700's Avatar
Grizld700
I've contacted several clamp suppliers and so far only 2 have responded and with negative results. Still looking for the clamp needed.
In the mean time I have zip tied the intake tube to the engine hook and so far that has been holding pretty well. But I would still prefer a more correct and finished look.
Old Apr 15, 2015 | 10:03 AM
67morris's Avatar
67morris
What does this hard JCW tube look like? Can you post a pic? I also just aquired a DOS inake after hearing what it sounds like in person.
Old Apr 15, 2015 | 10:57 AM
Grizld700's Avatar
Grizld700
This isn't my car, but its the same intake tube:
And ignore the catchcan with the hose going to the intake tube.
Old Apr 15, 2015 | 11:03 AM
Grizld700's Avatar
Grizld700
Also, like you once I heard this intake, I had to get one. I'm very happy with it (other than the fitment issue). Nice sound that, to me anyway, isn't too overbearing while still being very exciting.
Old Apr 15, 2015 | 12:14 PM
How old in the JCW intake tube? Did you transfer the old gasket to the newer pipe ?
Check the old outside tube connection it might have a crack an damage near the turbo inlet connection. Also check the worm belt clamp threads as when they are over tightening on and off allot they can get chewed up and back off.
13717582453
http://www.ecstuning.com/Search/SiteSearch/13717582453/
and clamp 13717577548
http://www.ecstuning.com/Search/SiteSearch/13717577548/ES35254/
Old Apr 15, 2015 | 12:19 PM
Grizld700's Avatar
Grizld700
Thanks for your input ECS. I installed the JCW inlet hose I purchased from you about a month ago, transfering the gasket over to the new pipe. I tried a new generic worm clamp since I have a ton of them where I work, but that didn't help either
Old Apr 15, 2015 | 12:22 PM
Yea, Sounds like there intake design fighting the natural contour of the pipe. Make sure the little gasket and the pipe itself is clean or oil residue. Also did you try a new factory clamp when you switched it over ?
Old Apr 15, 2015 | 12:36 PM
Grizld700's Avatar
Grizld700
... Also did you try a new factory clamp when you switched it over ?
No, but I have a feeling that's what i'ts going to come down to.
Old Apr 15, 2015 | 04:20 PM
67morris's Avatar
67morris
I have the same tube. So, is it slipping off the turbo inlet side?
Old Apr 15, 2015 | 04:31 PM
cerenkov's Avatar
cerenkov
IIRC on some of the first DOS intakes, the filter housing outlet tube which goes to the MAF housing was too long. If this is the case it needs to shortened by just trimming it down (I would use a belt sander). If the DOS filter housing outlet tube is too long it will put stress on the connection to the turbo inlet.
Old Apr 16, 2015 | 06:16 AM
Grizld700's Avatar
Grizld700
^This is it. I've looked at photos and I would swear my outlet tube on the DoS intake was longer than everybody elses! It's definately one of the first ones out there, because Clint dated it with a sharpie. I have a 3" to 3.25" coupler coming my way from Amazon today, so after work I shall trim and apply the new coupler and hopefully this will end the story.
Old Apr 16, 2015 | 01:09 PM
J 13's Avatar
J 13
Mine looks long too and it was pretty hard to push it in the bulkhead, however, I am looking at a shorter inlet pipe.. I have a steel hard pipe that i dont feel like using. I want to add a red silicone pipe and possibly painting my DOS intake
Old Apr 16, 2015 | 01:46 PM
Grizld700's Avatar
Grizld700
Yep, it was a challenge. But I got it done. I decided to wait until this weekend to install the coupler, I'll have more time then. I will report back how it worked after that!
Old Apr 26, 2015 | 02:45 PM
67morris's Avatar
67morris
Hi! It looks like I have the same issue. So what do I need to get it to fit properly? Any updates?
Old Apr 27, 2015 | 07:47 AM
Grizld700's Avatar
Grizld700
Yeah I have a temp fix for now. I have a couple large black zip ties around the tube and connected to the engine hook ring right by the vacuum pump. It's been holding fine ever since. Now I have purchased a couple items to resolve the issue correctly. I have yet to install them. I wanted to do it in 2 stages to see if one is enough or if you need both. I'll update when I get this done. I'll try to stop being lazy. I burned myself out last week installing a ton of crap on the car, so I'm taking a break.
I'll update once I get this going. Sorry for the delay.
Old May 31, 2015 | 07:04 PM
67morris's Avatar
67morris
Here is my fix... It works great so far with the alta jcw hard pipe. I had to get back to the stock dv as jcw hard pipe wouldn't fit with gfb dv+. The best intake ever. The car sounds like a beast.
Attached Thumbnails DoS Intake Sliding Off... Need a clamp-jcw-alta-hard-pipe.jpg
Old Jun 1, 2015 | 12:54 PM
If you still have issues you can switch to the Forge N14 silicone intake pipe , it has a different design and beefer clamp. Also does not have that double sleeve. We fitted it withe the ECS CF Intake and it was fine.
Has those huge made in england "Heart brand clamps"
http://www.ecstuning.com/Search/SiteSearch/FMR56IND/
Old Jun 1, 2015 | 06:22 PM
kyoo's Avatar
kyoo
http://www.frozenboost.com/t-bolt-cl...39011528cf3296
hoses popping off is a pretty common problem for evos - just ordered a bunch of these myself ^
Old Jun 1, 2015 | 07:08 PM
67morris's Avatar
67morris
Thanks! Cool website... literally
Old Jun 2, 2015 | 08:45 AM
Grizld700's Avatar
Grizld700
I've checked this site out before, all of their clamps have a .75" band. I need something much smaller to use with my JCW hose. The band needs to be 9mm or about 3/8". :-/
Old Jun 2, 2015 | 09:27 AM
kyoo's Avatar
kyoo
damn.. check with napa? what's holding it now that it's slipping off with? worm gear?
Old Jun 2, 2015 | 09:44 AM
Grizld700's Avatar
Grizld700
It's the original stock clamp. I tried another worm gear styled clamp and it didn't hold any better.
Old Oct 19, 2015 | 09:00 AM
basil49's Avatar
basil49
me, too --
I ALSO have a DoS CAI on a stock inlet tube, and that stock tube keeps slipping off at the turbo end of the assembly ...
1. Yeah, I also put a Big Honking Ziptie on mine, around the tube and through the engine hook, which is holding so far.
Glad to see I wasn't the only one who thought of this (ugly) hack --
2. Anybody here try THIS product to keep their intake-tube on the turbo? http://www.detroittuned.com/detroit-...-inlet-flange/
It looks like you hafta heat it up to force-fit it to the turbo, and gives you a nice hard LIP to help the hose-clamp:
Follow-up: sorry; just found the thread discussing DT's product: https://www.northamericanmotoring.co...rbo-inlet.html
Old Oct 19, 2015 | 02:26 PM
Yep. The replacement factory clamp and check connection would be the first thing to try.
Inziladun
Sep 3, 2015 10:35 AM
jwillis
Sep 2, 2015 02:19 PM
Lurts
Aug 29, 2015 10:29 PM
tacticalbacon02
Aug 22, 2015 06:05 PM
ASRman
Aug 13, 2015 09:33 AM
