R50/53 Steering Column Boot Weirdness
Old Mar 11, 2015 | 08:11 AM
mikes603's Avatar
mikes603
I noticed the other day that there is a boot flapping around my steering column. And there is already one currently installed in the firewall. Is this suppose to go over the firewall boot? Or did the factory give me an extra? Seems superfluous.
Old Mar 11, 2015 | 09:04 AM
Its the other one , Seals for weather and sound. Its hard to get back on that lip seal, start it on the lip and then work it around till sealed on the firewall.
Old Mar 11, 2015 | 09:13 AM
mikes603's Avatar
mikes603
It's that schematic that has me confused. It's not #6, as that's the firewall boot already in place. This is a flat boot that I don't see on that schematic. ...?
Old Mar 11, 2015 | 09:30 AM
Yes number 6 is the ones that is already there " 32131504578 " . And comes with that boot on the outside ( that fell off) with it , even though the diagram does not show it.
Old Mar 11, 2015 | 09:32 AM
mikes603's Avatar
mikes603
I see. It, #6, is really a sub-assembly falling under one part#. Thanks for the help!
Old Mar 15, 2015 | 02:41 PM
Fizzyx's Avatar
Fizzyx
Mine has been flapping around ever since I dropped the front subframe. I lost patience trying to get it back together. Any tips? Soap?
Old Mar 16, 2015 | 05:48 AM
Used a small flat head and worked it from the side while pressing down the lip. It was a bit of a pain to get back on. Took a couple times.
http://www.ecstuning.com/Search/SiteSearch/32131504578/
Old Jun 27, 2015 | 09:12 AM
subguy658's Avatar
subguy658
We just found this cover loose as well this morning. Car is already back on the ground, so we'll try to get it back on next time...
Old Jul 10, 2015 | 07:03 AM
Its a pain , but you can work it back on.
Old Nov 4, 2015 | 12:27 AM
musicguy123's Avatar
musicguy123
On which side of the firewall does it end up sitting once the two parts have been combined? the inside of the car (footwell), or the outside?
I ended up separating mine dropping the sub-frame as well...
Old Nov 4, 2015 | 08:55 AM
The one boot clips to the out side of the firewall ( closest to the engine bay) and the other one goes under it.
Paul!
Electrical
16
Feb 18, 2025 06:29 AM
bahman
Nov 15, 2019 05:45 AM
Supertractor3
Apr 7, 2017 11:16 AM
67morris
Dec 1, 2015 12:53 PM
Filmy
Sep 7, 2015 11:27 AM
