Tensioner Question
Old Mar 6, 2015 | 01:23 PM
York's Avatar
York
Tensioner Question
I replaced the timing chain tensioner on my 2009 MCS with the new model. The original was not tight and was seeping oil. Should I expect the new one to back out over time and require periodic tightening?
Old Mar 7, 2015 | 07:59 AM
DOC4444's Avatar
DOC4444
Not if you installed it with Loctite on clean threads. Also, you need to replace gasket with a new one each time tensioner is removed and replaced.
DOC
Old Mar 7, 2015 | 08:15 AM
Helix13mini's Avatar
Helix13mini
...and hopefully your chain isn't stretched or your guides worn/broken. That'll add to the headache.
Old Mar 8, 2015 | 02:08 PM
York's Avatar
York
OK thanks, didn't use thread lock so I'll keep an eye on it. I hope that the chain and guides are OK, time will tell. I will be prepared to replace the entire assembly when needed but if I bought a few more years for $37 I will be happy.
Old Mar 8, 2015 | 02:09 PM
York's Avatar
York
The old tensioner didn't have thread lock on it and I did not see that recommendation in my research. Seems like a great idea.
Old Mar 10, 2015 | 03:10 PM
nkfry's Avatar
nkfry
No, with the threads clean and proper torque applied to the tensioner you should not have an issue. Spec on it is 45 ft lbs, we usually add a bit extra to ensure it doesn't back out over time.
Nick
Detroit Tuned
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Mar 11, 2015 | 11:59 AM
York's Avatar
York
Great, thanks!
Old Mar 12, 2015 | 12:22 PM
The newest tensioner has a little bump on the back of the hex head for the stock size 78mm ~895 part. And then just torque to that set amount. Should be fine.
Old Mar 13, 2015 | 01:46 PM
York's Avatar
York
I installed the x482 tensioner.
Colt45Magnus
Aug 27, 2024 05:03 AM
Manny_cooper
Sep 3, 2015 05:48 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
Aug 7, 2015 09:51 AM
