Tensioner Question
I replaced the timing chain tensioner on my 2009 MCS with the new model. The original was not tight and was seeping oil. Should I expect the new one to back out over time and require periodic tightening?
Not if you installed it with Loctite on clean threads. Also, you need to replace gasket with a new one each time tensioner is removed and replaced.
DOC |
...and hopefully your chain isn't stretched or your guides worn/broken. That'll add to the headache.
OK thanks, didn't use thread lock so I'll keep an eye on it. I hope that the chain and guides are OK, time will tell. I will be prepared to replace the entire assembly when needed but if I bought a few more years for $37 I will be happy.
1 Attachment(s)
The old tensioner didn't have thread lock on it and I did not see that recommendation in my research. Seems like a great idea.
Attachment 107156 |
Originally Posted by York
(Post 4053400)
Nick Detroit Tuned |
Great, thanks!
The newest tensioner has a little bump on the back of the hex head for the stock size 78mm ~895 part. And then just torque to that set amount. Should be fine.
I installed the x482 tensioner.
