JCW Anyone track a regular jcw and a gp?
I have both.
Both are dedicated motorsport cars with FIA rollcages, seats and harnesses etc. The JCW is a circuit racing car and GP2 is a tarmac rally car.
I have driven both on the track completely stock and in various forms of modification.
The biggest difference is the tires, because the GP2 comes with dedicated type R track tires which make an enormous difference. However, even when you put those tires on the JCW the GP2 still has it all over the JCW.
The vast majority of the advantage of the GP comes down to the suspension setup. It is a track orientated setup, and just holds corner speed so much more, is more settled in transitions and handles bumps in braking much better. Also you can lower and balance the car, which makes big improvements again.
The other differences, ie bigger brakes, aero, mild power increase make very little difference really.
Having said that, if you spend $2k and put a decent quality set of coilovers on a JCW, and then put the track tires on, they are neck and neck.
I have both. Both are dedicated motorsport cars with FIA rollcages, seats and harnesses etc. The JCW is a circuit racing car and GP2 is a tarmac rally car. I have driven both on the track completely stock and in various forms of modification. The biggest difference is the tires, because the GP2 comes with dedicated type R track tires which make an enormous difference. However, even when you put those tires on the JCW the GP2 still has it all over the JCW. The vast majority of the advantage of the GP comes down to the suspension setup. It is a track orientated setup, and just holds corner speed so much more, is more settled in transitions and handles bumps in braking much better. Also you can lower and balance the car, which makes big improvements again. The other differences, ie bigger brakes, aero, mild power increase make very little difference really. Having said that, if you spend $2k and put a decent quality set of coilovers on a JCW, and then put the track tires on, they are neck and neck.
Did you have issues with the brake caliper Pistons? I know a lot of people here say they must be swapped. If I can get essentially the same car in the R58 JCW with the bilstien coils and tires thenI am just going with the r58. I am no pro I will just be doing track days at my local track for fun not competing.
Exactly what I wanted to know!
My JCW brembo 4 pots probably went through 3-4 sets of track pads before I rebuilt them. I have been more proactive rebuilding the GP2 calipers because I knew it would become a problem.
Good news is there are kits to rebuild them, I saw on another thread there is now a dedicated kit for the 4 pots now.
Either car if you know that it is going to do a lot of trackwork it is probably worth fixing the pistons straight up. If you are just doing the occasional track day don't worry and see how they shape up
Yeah there is this kit: http://www.racingbrake.com/Save-10-o...p/bb-41bsp.htm
Looks not that difficult: https://www.racingbrake.com/SearchResults.asp?Cat=7123
So did you only have to rebuild the front?
Also do you even need the dust boots? They likely melt off anyway.
Shims would help slow piston deterioration. however, rebuilding the pistons is a better and permanent solution. shims can make it a little harder to fit in new pads as well.
The dust boots / piston seals do need rebuilding every now and again, but that is pretty normal for any tracked car.
PelicanParts.com
Aug 4, 2015 02:45 PM
