R50/53 coolant flange torque specs?
Old Oct 16, 2014 | 08:14 PM
majestic's Avatar
majestic
does anyone have the torque specs for the coolant flange that bolts to the front of the block on the engine on a 2005 mini cooper S? currently replacing my water pump, ive heard 30 ft-lbs and ive also heard 6-9 ft-lbs. the bolts are just two 10mm bolts. the part im talking about is here.
http://www.ecstuning.com/Mini-2005-C...anges/ES24417/
Old Oct 17, 2014 | 04:54 AM
1qwkmini's Avatar
1qwkmini
Some of these numbers are hard to find or decipher which part they are actually referring to. Anyway, my resources say 8-12 NM (seems to be the same part listed 2 ways) so 6-9 ft-lbs is right--it's only a 6mm bolt and you only really need to compress the o-ring to seal the flange--9 ft-lbs won't hurt the bolt or the o-ring ( I use 9).
KinetechMW
Jan 22, 2016 09:04 AM
one73ronin
23
Sep 22, 2015 09:56 AM
hydouken
Sep 15, 2015 05:49 AM
papawhiskey
Sep 14, 2015 05:47 PM
cw40342
Sep 2, 2015 06:01 AM
