Passenger door won't open from the inside or outside.
Old Oct 7, 2014 | 08:22 PM
saturn5rocket's Avatar
saturn5rocket
The passenger door on my 2002 Mini Cooper will not open from the inside or outside. I replaced the actuator. The door then did open from the inside and outside a couple of times. I was about to put the door panel back on. Now the door doesn't open again?? The door unlocks and locks. I checked all the cables. All the cables are attached and working, but the door still isn't opening. Faulty actuator??? Is there some kind of reset?? Fuse?? Help.
Old Oct 26, 2014 | 04:07 PM
saturn5rocket
UPDATE: I broke down and took the Mini to a shop. Turns out the exterior passenger side handle was bad. It was preventing the latch from opening from both the inside and outside. The cable from the exterior handle to the actuator was also slightly stretched. $62 for a handle and $11 for a new cable. The door is now opening and closing as it should.
Old Oct 28, 2014 | 04:03 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
yeah that short little cable is attached / comes with the exterior handle... Thanks for the update !
Old Oct 29, 2014 | 07:46 AM
Yep,
Just for reference it looks like this for the cable attached to the handle. Then there is the cable that goes from the lock to the inside handle. Chrome version linked below for the handles , there are also checkered and Union Jack version door handles. .
https://www.northamericanmotoring.co...wont-open.html
sevin
May 2, 2026 06:11 AM
W0TM8
Dec 19, 2019 07:50 AM
polotska
Aug 23, 2015 03:03 PM
chicohuahua
22
Aug 20, 2015 11:17 AM
