R56 Help with OBD-2 Software
Old Oct 3, 2014 | 05:51 PM
MattSaint's Avatar
MattSaint
Help with OBD-2 Software - IOS / WiFi / Dash Command
I've tried a couple different pieces of software. The first of which is OBDCOM with their provided USB Cable. I can connect to the car but all that I am able to retrieve is the RPM's and trouble codes (although the Dash Command found some but this piece of software didn't). I have the latest version of the software. If I connect to my Pontiac Vibe I gain access to other more useful information. Coolant Temp, O2 sensors etc...
I then purchased an ELM compatible WiFi dongle and the Dash Command iPhone/iPad app. Again I can connect, but I can only retrieve RPM information as well as trouble codes. As mentioned above, when I connect to my Pontiac Vibe I can access all sorts of other information.
Am I missing something? Could it possibly have to do with the JCW Tuning Kit upgrade that I have installed in my MCS? I am at a loss at this point, because other people seem to be able to retrieve coolant temp, oil pressure etc...
Best!
~MattS
Old Oct 8, 2014 | 04:02 PM
MattSaint's Avatar
MattSaint
Update
So, I did more research and I discovered that some of the cheaper WiFi dongles can and sometimes will generate misfire codes as well as other electrical anomalies. I decided to return the one I purchased after a friend brought over his bluetooth version in conjunction with the Torque app and it worked with no issues what so ever and more importantly no codes. Which leads me to believe that the Dash Command app does NOT work with my Mini. I'd love to be proved wrong regarding my last statement, but after trying it on different version of iOS I was unable to get anything other than RPMs to display.
If you have an iPhone/iPad and are using a WiFI dongle and an App to display coolant temp and Oil pressure and Boost I would very much like to hear from you.
Best!
~Matt
Old Oct 8, 2014 | 05:31 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
Using the Kiwi II wifi adapter and DashCommand for a while. IOS6 and now IOS7. My normal display shows RPM, boost, water temp, outside air temp, intake temp, lambda and exhaust temp. It will not read BMW specific error codes, only OBDII codes. For data logging I have it record RPM, boost, AFR, timing and IAT.
Old Oct 8, 2014 | 06:16 PM
MattSaint's Avatar
MattSaint
I've tried iOS6 and iOS8, I don't have access to iOS7. So, this worked for you out of the box? Any changes to the configuration? Adding any PIDs? It didn't recognize the Cooper S, just Mini...
Old Oct 8, 2014 | 07:20 PM
cerenkov's Avatar
cerenkov
Weird.
I've been using DashCommand for sometime and never have had any issues. I've used both cheap wifi adapters and expensive ones.
Old Oct 10, 2014 | 05:48 AM
MattSaint's Avatar
MattSaint
Any recommendations for other Apps that would work with our cars? I am hesistant to spend another $10+ that may or may not work.
Thank you!
~Matt
Old Oct 10, 2014 | 05:58 AM
cerenkov's Avatar
cerenkov
Wait I'm confused, have you not already purchased and tried DashCommand?
Old Oct 10, 2014 | 06:25 AM
MattSaint's Avatar
MattSaint
You are correct. It only reads RPMs, nothing else.
Old Oct 10, 2014 | 09:19 AM
cerenkov's Avatar
cerenkov
I had that issue when I first used ScanXL (windows based program from the same makers) but not with DashCommand. Contact them they should be able to solve the problem. They do have an active online forum.
Old Oct 11, 2014 | 11:04 AM
MattSaint's Avatar
MattSaint
Thanks! I took your advice and posted on their forums. John replied and had me make some timeout and delay adjustments. This in conjunction with 'checking' the Disable OBd-II Mode Support as well as going into each of the PID categories and checking all the ones that are green allowed more data to be displayed. Now the only monitor/gauge that is incorrect is boost. Quick question for you ... what value did you use for 'brake specific fuel consumption' ? They specify forced induction as .50 to .60, but call out turbo diesel as .35. Default is .44. Thoughts?
Old Oct 11, 2014 | 11:35 AM
cerenkov's Avatar
cerenkov
Cool. I use 0.5 for bsfc. Seems reasonable but I really have no idea what number is ideal for our car.
Old Oct 11, 2014 | 04:33 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
A friend of a friend of my uncles plumber who once say a mini said it was .55 lol.
Old Oct 11, 2014 | 04:34 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
Saw not say. Damn you autocorrect.
Old Oct 25, 2014 | 04:23 PM
ptguy0618's Avatar
ptguy0618
Does the kiwi II have to be on wifi? I need an adapter for my iPhone 5s, not sure how I'd be on wifi while driving?
Old Oct 25, 2014 | 04:46 PM
cerenkov's Avatar
cerenkov
It's a peer to peer ad hoc network (not to the Internet).
Old Oct 27, 2014 | 09:28 AM
Seaswood's Avatar
Seaswood
Torque app
So do I get this right the Kiwi II is the dongle. (PLX devices) plugged in?
Bluetooth OBD2 is plugged into obd port in car.
Torque app on phone I have a 4s iPhone.
Old Oct 27, 2014 | 10:53 AM
cerenkov's Avatar
cerenkov
Originally Posted by Seaswood
So do I get this right the Kiwi II is the dongle. (PLX devices) plugged in? Bluetooth OBD2 is plugged into obd port in car. Torque app on phone I have a 4s iPhone.
Yes, Kiwi 2 is one that will work, it's not the only one, it's just also compatible with PLX devices if you have those too. Anything that is ELM327 compliant should work. There are Bluetooth, wifi and usb dongles. Be careful of Bluetooth versions if you are going to be using an iPhone (most won't work from what I understand). IIRC Torque is an Android only app. I like DashCommand when using an iOS device.
I personally use OBDLink Wifi from scantool.net because I was hoping for faster scan rates using the optional usb connection to the laptop. But there are much much cheaper versions that will work just fine. Here's a link:
http://www.ebay.com/bhp/obd2-wifi
Old Oct 27, 2014 | 03:08 PM
Seaswood's Avatar
Seaswood
Okay so there are a lot of choices on that link, being a techno moron?
Which one works with the mini & iPhone 4?
Some say mini does that refer to the car or ?
Some specified to later version of iPhone also
Pker
Apr 11, 2017 12:14 AM
jetmechinnc
Nov 18, 2015 08:54 PM
jcwmini04
Sep 20, 2015 04:52 PM
PSU 98
Sep 11, 2015 11:20 AM
Richard Kellstrom
Sep 4, 2015 07:21 PM
