R52 broken window (rag top)
Old Sep 22, 2014 | 05:33 AM
cg1's Avatar
cg1
Hello friends - I have a 2008 JCW convertible. Sadly, the rear window was smashed by kids (presumably) last evening. I called my local Mini dealership and was told I must replace the entire rag, the part is 2,000 and the labor is roughly 1,600 (10 hour job). I thought I would be able to replace just the window :(
Anyone have this happen before? is there an alternative after market maybe? I hate the thought of putting nearly 4K into a 6 year old car with 120K miles. thanks !
Old Sep 22, 2014 | 07:13 AM
See here on the Genuine MINI top. Have not seen to much aftermarket and the ones I have seen did not look as good fit and finish.
I would also check with your insurance company as the rear glass is bonded to the convertible top and requires the whole top replacement. Your insurance should pick up the repair.
It also gives you a chance to possibly change the color.
#2 is the top.
Part # for the top 54347135290 Black , 54347135291 Blue , and 54347135292 Green
54347135290 Folding Top Fabric - Black
http://www.ecstuning.com/Search/SiteSearch/54347135290/
54347135291 Folding Top Fabric - Blue
http://www.ecstuning.com/Search/SiteSearch/54347135291/
54347135292 Folding Top Fabric - Green
http://www.ecstuning.com/Search/SiteSearch/54347135292/
Old Sep 22, 2014 | 07:55 AM
cg1's Avatar
cg1
Thank you. I called my insurance company and it is covered as well as 80% of a rental car up to $500. Looks like I will have a $500 deductible and a small amount of a rental car.
Such a shame. But on the bright side, having never had an insurance claim before this will not effect my rates. thank you for the feedback and information !!
Old Sep 22, 2014 | 08:08 AM
Great, glad I could help.
another tip: This will be a project for the MINI dealership or install body shop. Make sure they know what they are doing ahead of time, its time consuming. If you do have a MINI dealership ( which i recommend) do this they can sometimes provide MINI free loaners dependent on where you are and if you call ahead and schedule.
Cover the rear window as much as you can so you don't get any water in there. Plastic sheeting and heavy duty tape for temp.
You have the part number above. And nice to see a MINI Sidewalk edition get proper care from you .
Old Sep 22, 2014 | 08:19 AM
Capt_bj's Avatar
Capt_bj
Robbins specializes in replacement tops for 'verts
and I'd think hard about using the dealership or a standard body shop ... convert' tops are NOT their thing. The Robbins site has a list of recommended installers or check your local area ... you'll probably get a better result from someplace with experience . . . (the dealership most likely will subcontract the work and add a markup ... find out who they use)
http://www.robbinsautotopco.com/index.php
log time owner of various rag tops sends . . .
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
UncDeo
Nov 4, 2019 04:08 AM
Sep 2, 2015 11:15 AM
hardy616
Sep 2, 2015 08:32 AM
cw40342
Sep 2, 2015 06:01 AM
