Suspension H&R Springs - can I do it?
Old Jul 1, 2004 | 12:46 PM
g3's Avatar
g3
I am very interested in the H&R or H Sport springs. Thing is, I need to get advice from the NAM community as to whether they will work on my ride. Right now, I am running 215/45/17 Yokos on 17X7 rims with stock suspension on a 2003 MCS. When the car is under load (4 adults). I get a little rub when I fly over a dip in the road (our streets here in the Big Easy are awful). Am I putting myself in a world of hurt by lowering the car another 1.5 inches with the H&Rs? Do I need to wait till I wear out my 45's and buy a different set of tires next year?
Old Jul 1, 2004 | 04:02 PM
kenchan's Avatar
kenchan
What is your wheel offset, btw? You can probably dremel a little part of
the rear fender arch on the inside to remedy the rubbing. Alex and Minihuni
over at the tires, brakes, etc forum has some info on the dremeling.
If you plan on driving around with 4 adults often, you might want to
get a coilover kit (higher spring rate, higher damping capacity) as
you may be driving around on the bumpstops with full load.
I would definitely recommend the Hsports between the 2 choices
you listed. :smile:
Old Jul 1, 2004 | 04:31 PM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
i have found after installing a few sets of springs is that all cars sit different. h-sports are the ones i pick to be the best handeling spring, but only drop the car abut 7/8 of an inch max. and that is on a fully loaded, leather int, sunroof car. if you do not have some of the options it will not get that low. the other springs i believe are lower. i put a set of KW's and they are a full inch. in the end you might want to go to a different tire. the low look of sport springs is just the best. hope that helps.
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Jul 1, 2004 | 07:14 PM
pocketrocketowner's Avatar
pocketrocketowner
I run 35 aspect 18 inchers with the green K&N springs....no probs at all.......though I have never had four adults in it........they can get their own damn MINI if they want to ride around in one.......
Old Jul 5, 2004 | 12:14 PM
Thameth's Avatar
Thameth
you listed. :smile:
What makes you go with the H-sports over the H&R's?
Old Jul 5, 2004 | 08:57 PM
kenchan's Avatar
kenchan
1inch drop on all corners. Most lowering springs can not drop the car flat.
I had previous bad luck with H&R's on my other car. H-sports come complete
with illustration instructions and new bump stops.
Old Jul 6, 2004 | 04:45 AM
Thameth's Avatar
Thameth
Sometimes though you don't want the car to drop flat. If the car has a bit of a rake in stock form then when you drop it flat it won't end up flat. On my old 93 Civic Sedan most people would drop it flat and the rear end would sag on the floor. But i bought an eibach kit that left rear higher and it sat flat when lowered.
Old Jul 7, 2004 | 10:25 AM
kenchan's Avatar
kenchan
its been flat for the last couple of months since i installed it.
Prokit on my other was sitting 1/4" slanted on the rear too.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
CooperSharp
Oct 12, 2015 09:21 AM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
nshannon29
Sep 30, 2015 05:21 PM
