R56 Mini Cooper S 2010 w/ HK stereo wire codes.
Old Sep 11, 2014 | 05:26 PM
Rodrigo Constantino's Avatar
Rodrigo Constantino
Hi guys
My wires just didnt fit any description in a whole google and forums search
I will post all colors and sizes here:
Thick cables:
- Black
- Gray/Red
- Red/Green
- Brown/White
- Two equal Green Fiber Optic cables
Thin cables:
- Green
- Green/Orange
- Blue/Black
- Blue/Brown
- Gray/Yellow
- Gray/Violet
- Gray/Blue
- Gray/Brown
Ive cut off all wires and cant install original radio back either. What a waste. Bought one KDC-X998 and cant use it.
If you guys got any question, ask me and i'll answer, i'll post pictures if needed.
Thanks for your time
Old Sep 11, 2014 | 07:10 PM
Rodrigo Constantino
Here come some pictures.
Attached Thumbnails Mini Cooper S 2010 w/ HK stereo wire codes.-cam02748.jpg   Mini Cooper S 2010 w/ HK stereo wire codes.-cam02769.jpg   Mini Cooper S 2010 w/ HK stereo wire codes.-cam02755.jpg   Mini Cooper S 2010 w/ HK stereo wire codes.-cam02750.jpg   Mini Cooper S 2010 w/ HK stereo wire codes.-cam02778.jpg
Old Sep 11, 2014 | 07:20 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
So why did you cut all the wires?
Old Sep 11, 2014 | 07:26 PM
Rodrigo Constantino
Was about to wire one by one with kenwood harness.
Old Sep 11, 2014 | 07:31 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
Okay..so is your HK amp still in the car? The factory head unit communicated to the amp in order for it to work. Are you trying to hook your kenwood to the factory amp?
Old Sep 11, 2014 | 07:45 PM
Rodrigo Constantino
Just removed the head unit and nothing more.
Yes i want to make it all run in kenwood head unit.
Old Sep 11, 2014 | 08:03 PM
Rodrigo Constantino
Perhaps i will need a fiber optic to rca converter either?
Old Sep 11, 2014 | 08:13 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
Heres the way I understand it.. If you are going to use an aftermarket head unit and still use the factory H/K amp in the car you will need to get what I think they call the H/K Enabler. But if you have cut wires already im not sure how that would work for you now. Maybe someone else can chime in here for you! Did you remove the H/K amp?
Old Sep 12, 2014 | 06:09 AM
Rodrigo Constantino
And if i only change the amp? Could be better done?
Old Sep 12, 2014 | 06:41 AM
richardsperry's Avatar
richardsperry
Sorry, but why the heck would you cut all the wires without you knowing exactly what you are doing? Or what the consequences are?
Old Sep 12, 2014 | 08:20 AM
Rodrigo Constantino
That was for sure a big mistake. Didnt thought the car was so hard to make that kind of change.
Old Sep 12, 2014 | 06:50 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
The H/K system in the MINI is integrated into the car. Not at all easy to just swap to an aftermarket head unit. Cutting those wires was a real no no! At this stage im not sure what might be better for you. If you decide to run an aftermarket amp along with your kenwood you will have to run all new speaker wires and then im not sure you can even use the factory speakers. The H/K amp also acted like a electronic crossover. I would try to splice those wires back together..Good luck!
Old Sep 18, 2014 | 10:39 AM
Rodrigo Constantino
Hey guys.
If i go to mini cooper dealers and manage to get back my oem deck working normal with the wires i cut... this thing would do the trick to get better sound?
http://soundstream.com/store/car-aud...s/harmony.html
Old Sep 18, 2014 | 10:46 AM
doseddies's Avatar
doseddies
You have three choices. Put it all back. Buy an HK enabler. They are available through Mike's Mini.
Run wires to the speakers yourself, bypass the HK amp.
Old Sep 19, 2014 | 03:58 AM
richardsperry
I guess it all depends on what you want to do.
I actually think the HK system is pretty good, with the exception of the crap bass. The addition of the Integral Audio sub fixed that.
iggi
18
Feb 9, 2026 01:00 AM
Minii cooper bean
Aug 11, 2015 02:10 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
