anybody running 215/40/17 on their set up
Old Jul 1, 2004 | 08:53 AM
asaulo1's Avatar
asaulo1
Just wondering if anyone is running this spec on their tires.... thanks.:smile:
Old Jul 1, 2004 | 09:16 AM
mtrspt5's Avatar
mtrspt5
I'm running those size tires and recently had my first track session with them. See below for mods. Since I haven't used 215/45/17s I can't compare the difference. I have no issues with the 40s
Old Jul 1, 2004 | 09:43 AM
Mjolnir's Avatar
Mjolnir
Yep
I run this with the Goodyear Eagle F1's. I previously ran 45 Series with Yoko AVS ES100's.
The Goodyear is a FAR superior tire to the Yoko so that's no comparison.
Technically, you are over your weight limit on a 215 40 but I've never had a problem nor has anyone else I've known.
Cheers!
-Jim
Old Jul 1, 2004 | 10:15 AM
AMPR's Avatar
AMPR
I just had 215/45/17's installed. There was definitely a noticeable improvement over the Pirelli run flats, but I'm still adjusting to the ride.
Old Jul 1, 2004 | 10:20 AM
10851CS's Avatar
10851CS
Yes, I am running them with H-sport springs.
Earl
Old Jul 1, 2004 | 11:05 AM
ChiliBit's Avatar
ChiliBit
Yes, with Proxes T1s on 17" Team Dynamics wheels.
No problems.
I think 16 inch wheels make more sense in spite of what I have done.
Take a look at the sidewalls on an F1 car. Yes, I know, they specified by the FIA. But they get fair to decent handling from tall sidewalls. Maybe even better than fair to decent.
Old Jul 1, 2004 | 11:12 AM
dandp's Avatar
dandp
Look at the WIDTH of the tires on an F1 car....
I ran 215/40/17 Continentals on OZ Choron Evos without issue, through fall, winter & spring. Bad roads, potholes, you name it. No issues, no bent rims & no flats.
Old Jul 1, 2004 | 11:33 AM
kenchan's Avatar
kenchan
Jim convinced me about the GY's and I had to try it for myself on my MCS.
I think i might do the GS-D3's on my rex too next.
-Jim
Old Nov 2, 2004 | 12:03 PM
minimort's Avatar
minimort
what's the real difference between the 215/45's and the 215/40's? Just a spot of width?
Will both fit on stock s-lites?
Old Nov 2, 2004 | 12:27 PM
mycpr_s's Avatar
mycpr_s
Yes, they will fit both.
Old Nov 2, 2004 | 12:28 PM
minimort's Avatar
minimort
Any width or height difference?
Old Nov 2, 2004 | 12:35 PM
petecrosby's Avatar
petecrosby
Yes, either will fit the wheels. The difference is in the height, not the width. They are both the same width. Go to Tirerack for a better explanation of the specifications than I could give you. It's really pretty simple, though.
Old Nov 2, 2004 | 12:39 PM
minimort's Avatar
minimort
Thanks, will do
Old Nov 2, 2004 | 02:10 PM
SPIKE FRIEDMAN's Avatar
SPIKE FRIEDMAN
spike friedman
Yes, an using Toyo T1S 215/40/17 and they are perfect with the ALTA suspension and 241 HP . . . just had to shave 1/2 of the front valance
in order to clear bumps, etc. Spike in Portland @ 503 222-MINI
Old Nov 2, 2004 | 02:50 PM
Mjolnir's Avatar
Mjolnir
A nice little java app for tire size comparison...
http://www.miata.net/garage/tirecalc.html
sabjcw
Aug 14, 2015 07:40 AM
minipopkart
Aug 13, 2015 05:22 AM
wind715
Aug 11, 2015 07:56 AM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
