new HPFP yet no fuel to the rail?
Old Aug 29, 2014 | 03:08 PM
Lilnohm's Avatar
Lilnohm
so...My 08 MCS was cutting out like it wasnt getting enough fuel, and then surge like it had full power. I bought and replaced the HPFP and the fuel filter.
THAT is when it failed to start completely. so to eliminate a few things,
---in tank fuel pump works, and is connected to exterior power source to ensure continual fuel flow.
---fuel pump relay is bypassed
so fuel is getting to the HPFP, but nothing is coming out. The solenoid to the new HPFP is only getting 9-10volts when cranking which may be an issue, but IDK what the voltage to to the solenoid is supposed to be.
Can anyone help? have any ideas? It is a fuel issue not an ignition problem. Car will run when bypassing the fuel injectors by using starting fluid in the pcv tube that runs behind the throttle body.
i have read as many threads as i can about HPFP and Fuel pumps and filters ect.
IQRaceworks
53
Jun 28, 2024 07:29 AM
OutMotoring
Mar 3, 2017 06:29 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
HK_MCS
R58 :: Coupé Talk (2012+)
Oct 4, 2015 08:03 PM
dutchhome
Sep 30, 2015 07:17 AM
