Temperature gauge faulty
Old Aug 25, 2014 | 05:49 PM
mcart5's Avatar
mcart5
Have '05 MCS with faulty water temperature gauge(verified reads 25F high) in center crono gauge pod. Does anyone know if this can be fixed or does anyone have a working crono pod available.
Old Aug 25, 2014 | 09:46 PM
minsanity's Avatar
minsanity
Are you having start & idle problems? Your coolant temp sensor near the thermostat might have failed. If so, cheap & easy fix.
Old Aug 26, 2014 | 10:42 AM
ZippyNH's Avatar
ZippyNH
My suggestion....
Live with it...25°f is not very far off....changing parts can create a VIN# AND MILES mismatch since this info is stored in the 3 units....
Good luck...but this issue might be common....you just happen to find it...and the way you "verified" it could be agetting the temp from a separate spot....
When using guages TRENDS AND CHANGES are more useful than specific numbers....
Old Sep 2, 2014 | 07:35 AM
nkfry's Avatar
nkfry
I agree with Zippy, I would just live with it.
The coolant temp gauge could be bad, but if it was the car would most likely give you an undertemp/overtemp code.
Most of the temp/pressure gauges on modern cars are "dummy" gauges, they just show you an "in the general vicinity", people would freak out when all these gauges were going here there and everywhere, so unless you're overheating or still getting up to temp the needle won't move.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Sep 2, 2014 | 08:21 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
If the sensor is the issue reading 25* less than actual running temp, you engine will run rich like it's in cold start mode 24/7 giving some poor mpg figures.
If you have the Crono pack ( not sure if that is what you are referencing to ) and the gauge is the issue, not the sensor then maybe
simple re-programing may fix this.....When these kits were installed to 05/06's under a retrofit situation some programing was required at the dealer.
Old Sep 3, 2014 | 03:29 PM
mcart5's Avatar
mcart5
Temp Issue
In response to "gRay rAvEn" the car was ordered w/the Crono Pack and built to order. I don't know if the dealer installed the Crono Pack or the factory. My mechanic put in a new sensor which was not the problem. The mechanic said would have to get a new gauge. If this was an analog gauge I could pull the gauge needle and reposition it at the correct temperature. My mechanic used a Infra red temperature meter and confirmed the temperature was correct at 200F. I do not have start or cold problems as the temperature here is 90F and gas mileage is ok. The dealer said the gauge can only be replaced with a new Crono Pack and they no longer have them. Thanks all. MCART5
Doc Pain
Oct 28, 2015 07:09 PM
papawhiskey
Sep 30, 2015 02:50 PM
silence2-38554
Sep 28, 2015 12:19 PM
gnhovis
Sep 28, 2015 04:07 AM
daviday
Sep 25, 2015 01:31 AM
